Chain tensioner rebuild kit
I'm searching for rebuild kits for my stock 1974 2.7 mechanical chain tensioners. Pelican dosen't appear to have them. Anybody know where I can get them?
Thanks Harry
1974 911 2.7L coupe with sunroof |
The dealer for about $20 each.
CConnor 73E targa 89 Coupe |
Just curious, why aren't you going to oil fed chain tensioners...cost only, other reason?
Dan in Pasadena '76 911S Sahara Beige/Cork |
From the information that I got on this BBS, the pressure fed tensioners are not foolproof and can also fail as well. Re-built mechanical with the safety collar sounds like a pretty reliable setup unless someone convinces me otherwise.
Harry
Harry,
I went the same way as you, just keep an eye on them every 15k miles or so and when properly set up the mechanical tensioners are bullet proof. -My local mechanic has had a number or pressure fed tensioners fail over the last 5-10 years, and no longer automatically recommends them. |
Black and Blue
as long as the safety collar is on there, seems like it would be an easy inspection about the same time you do the valves. I dont know much about the safety collars, never used them. How would you know if a tensioner failed?
Kemo 1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore 1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver |
Black and Blue
wow...thats a confusing post, sorry bout that
Regular inspection is the key, regardless of which system you get,
re-sale down the road will likely be better with the Carerra tensioners, but real world reliability is not an issue so long as you re-install correctly, and inspect every 15k miles or so. |
Is tensioner inspection simply removing the tensioner covers and checking that the chain is tight or is there something else I should look for?
BUMP
1957 KR 200 Messerschmitt Bubble Car 3 wheeler-my first rear engined air cooled German car,alas long gone!. 1977 911S 2.7 to spend money on 2006 Tundra for acting grownup |
