DUK DUK is offline
DUK's Avatar
Another brake option question???
What would be the best scenario for my '75 as my stuff is junk: Find used "M" calipers and 19mm master cyl? VCI's setup for 930 calipers and put on my 3.0" struts? Or upgrade to 3.5" struts and use what? This is just a street car but I really would like to have a solid feel under braking. I like the feel of brembos on everything I've ever built. Ideas? Price wise I would like to stay in the $1000-2000 range. Thanx, Duke
75 911 Indian Red- RUFWAN2B 2000 Boxster
2000 & 2007 Dobies
www.stahlwerks.com Cages and preparation for your Porsche
“People who never make mistakes must get tired of doing nothing”
Bill : The origin of the orgy of Porsche
Old 12-29-2005, 06:25 PM
Bill Verburg's Avatar
The only "upgrade" for 3" struts is the BMW 320 caliper and that isn't much of an upgrade.
If you are serious, start w/ a set of 3.5" struts.
Your stock M/M brakes, if nominal, should give you the same solid feel as A/M or any of the other early brake combos.
For <$2000&#177 you should be able to pick up a new set of 3.5" Bilstein struts and Carrera front rotors, calipers, pads for a true upgrade. m/c need not(should not) be changed for this setup.
Bill Verburg
Old 01-02-2006, 04:18 PM
DUK DUK is offline
DUK's Avatar
Thanx Bill, I'm pretty sure this is the route I'm going to go. Im also checking out the feasability of using some brembos from work. Just got to figure out the offsets and rotors and adapters.
2000 & 2007 Dobies
Old 01-02-2006, 04:42 PM
randywebb's Avatar
It is always possible that Wevo will introduce their brake kit, and that there will be a version for your struts.... possible, OK? You could ask Hayden if there will be a version for you.
I like the Carrera struts on my '73. If you get the Al center piece at the same time, you get a tad lower wt. and add'l stiffness there.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 01-02-2006, 06:01 PM
