i removed and taped 5 and 6 and relocated 4 to the 6 spot. this is the holy grail of 911 tech crap. seriously, wayne might as well lock up the tech section. Nice job and thanks for figuring this out. -Bernie
Database and Website Consulting Services in Chicago |
Friend of Warren
Kurt V No more Porsches, but a revolving number of motorcycles. |
Nice Bernie!
Ed Hughes 2015 981 Cayman GTS 6 speed,Racing Yellow Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4 |
Friend of Warren
I'm hoping to try out jumping the reed switch first. That seems easiest to do. If that doesn't work then I will go with Bernie's solution.
).The only minor thing to note is that my 5 and 6 wires were yellow with a red line and dealing with that pin connector was a biatch. the numbers for the pins are clearly marked. i.e. pay attention to the pin numbers and not the wire colors. 4 was black. I did a bit of 'pin connector wiring' when I did my 3.6 swap and didn't enjoy it then either. Funny thing, those footwell blowers are my wife's favorite thing about that car. Plenty o' heat! I also discovered I killed my battery since I let it sit too long without running it this winter. dayum. I had to jump it to test it out, but i think i ran it down way too far and its not holding a charge. Oh, well... its great to cross another 'to do' off the porsche list! -bernie
Database and Website Consulting Services in Chicago Last edited by einreb; 01-05-2006 at 07:01 PM.. |
Without footwells, my system is semi-useless. I'm really looking forward to a solution.
Friend of Warren
You guys are fabulous! I've seen this issue discussed a million times, and now FINALLY someone's figured it out! Fantastic! Excellent work Ron!
Now, if I could just get my engine running properly, I could devote some time to this... ;( ianc
BMW 135i. Nice. Fast. But no 911... "I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79 |
Czar of C.R.A.P.
Just a reiteration of an earlier note. I also previously tried to jumper the reed switch to no avail. But this was because of some other issue with the controller. Same symtom footwell blowers no worky. This fix is only if everything else was working before the change to or elimination of the rear blower. If your footwell blowers just don't work the jumper solution won't do the trick. In my case a different controller solved problem even with a Dayton motor. Just something to keep in mind if the jumper doesn't work for someone.
66 912 Coupe 84 Carrera Cab Hardtop HC3.4 Hyper Carrera 2005 Dodge Magnum 5.7 HEMI Cabriolet Racing And Performance C.R.A.P. Gruppe #1 Put on some C.R.A.P. and drive.... |
Friend of Warren
My blowers work when I jump the blower relay in the engine compartment. Removed the engine blower.
If you still have an engine blower you must do the internal jumper at the reed switch. The end result of this jumper is that the footwell blowers will run even if the engine blower is toast. Andrew
'88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires '86 944NA, Sunroof Delete, Track Rat, Full Cage '72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic |
I think most here are trying to keep the footwells working with the backdate setup, I know I am.
Friend of Warren
bump
Hey great news..this has been an issue for a long time here.
Andrew, thats not true about the all blowers being on the same fuse after the mod. What is happening with the mod is you are removing the reed switch ( the permissive element ie: rear blower works, then footwells work) from the circuit. The rear blower is fused from fuse 1 on the rear panel and the footwells from fuse 2. The OEM wiring has the rear blower and the footwell relay solenoid on the same circuit and this doesn't change with the use of the jumper.
Peace, Ron www.ronorlando.net 78SC Targa 3.2 SS, 964 cams, CIS, SSI's,Dansk Own a gun and you can rob a bank , own a bank and you can rob the world. |
Great thread! How about a picture of a modded controller.
Bill 1987 Marine Blue 911 Carrera Coupe RIP 01/2011 1987 Black 930 RUF Coupe Resurrected, 2488 lbs, EFI Technology, UMS Tuned - Mild & Wild, Current in pieces at paint |
Kurt..great pictures! Here is a follow up on the circuit boards and two possible ways to modify the circuit. One from the back and one from the front. Again, I don't have the unit in front of me so let me know if the jumper placement is correct in the first picture. I sat here counting solder pads..I think its correct. As always with soldering don't overheat the pads and don't flow solder onto the pads near by. The mod shown in second picture might be easier for some people because it just connects the reed switch pigtails together. Its not as sexy as the first but you are less likely to over heat the pad and have the switch come loose. It appears that the factory didn't attempt a 90 degree bend and poke the ends of the reed switch thru the holes in the pads. Once we get all this sorted out I'll cut and paste it into another document to make it more of a how to..good work team!!
Mod one: Alternate version of mod:
Friend of Warren
Ron I plan on going with wire connecting the two ends of the reed switch together as you show in the second photo. I will do it tonight and post the results tomorrow. Your knowledge and the posting of the diagrams by the others in this thread might make for an easy solution to keeping the footwell blowers!
Here's a question though. I have read in a few places that in the later models, the factory changed the circuit so that position '0' on the rotary switch makes the footwells run all the time, albeit very slowly. It seems to me that with this mod (removing the dependency on the main blower), if your blowers run at '0', they will always be running now, even in summer?
Anybody done it and seen this yet? ianc Edited later to say: This post was made by someone who just didn't quite get it yet.
BMW 135i. Nice. Fast. But no 911... "I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79 Last edited by ianc; 01-10-2006 at 11:06 PM.. |
Did anyone "reverse engineer" (draw a schematic of) the control module? It is simple to do it with these old thru hole parts PCBs (as opposed to SMT with blind and buried vias etc).
I'm curious. Anyone got a dead one they can sell me (for postage cost)? |
I think we agree on the the reed switch by-pass. Not a problem other than losing the "permissive" feature you mentioned. The point that I was trying to make (and didn't do a good job of) was that the reed switch jumper is the only mod that will work with a engine blower still installed. As for the engine blower and footwell blower being on the same fuse, yep, I was confused on that one. Don't know what I was thinking, I didn't sleep in a Holiday Inn last night Quote:
The "0" and "1" setting on the rotary switch are the same speed. I think this was the case for all Carreras but I don't have experience with the earlier Carerras. I believe this was done because if the footwell blowers are actually OFF the fan cage partially blocks the path of the heated air. The engineers decided they should run even when "OFF". Having said that my car will get mighty hot without the FW blowers working so I don't know how much air it blocks. With the reed switch jumper the FW blowers will only run when the heater levers are up, just as they do normally. As Ron noted above all you are doing with this mod is by-passing the feature that won't let the footwell blowers run unless the engine blower is running. Andrew
'88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires '86 944NA, Sunroof Delete, Track Rat, Full Cage '72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic Last edited by aj88cab; 01-06-2006 at 10:50 AM.. |
