addictionMS's Avatar
odd wiper problem
My 1988 Carrera has developed a strange problem with its wipers. When the ignition is on, but the motor is not running, they work fine, washer, low, medium and high, intermittent, everything is as it should be. BUT once the motor is started they run continuously in low.
I have taken apart and cleaned the switch, I did this before I figured out the problem was only when they motor was running.
So I figure it can only be something to do with the charging system or a system that is not powered if the motor is not running like the fuel pump.
I have looked at the schematic and can not see how this is possible.
Any suggestions?
Thanks in advance
Jim
Jim Hamilton
If everything seems under control, your not going fast enough.
Old 12-30-2005, 04:28 PM
Don Plumley's Avatar
An English ghost has taken residence in your car. It's all this rain, they are confused.
Sorry for not being more helpful...
Don Plumley
M235i
Old 12-30-2005, 05:55 PM
thanks for the insight, I will start the exorcism tomorrow.
jim
Jim Hamilton
Old 12-30-2005, 06:51 PM
bumping, it is raining now so it is not a problem, but tomorrow is calling for sunshine.....
Jim
Jim Hamilton
Old 12-31-2005, 08:07 AM
