brittbolen's Avatar
How do you unhook the taillight assemblies from the harness?
How do you unhook the taillight assemblies from the wiring harness? I want to pull them out for my repaint, and also to restore them (they have overspray from a past repaint, and some corrosion on the reflectors) I searched and search but never saw this question...
thanks,
Britt
Old 12-31-2005, 10:15 PM
Bird. It's the word...
Fishcop's Avatar
The harness joins just inside the engine bay to the rear at each side. Unplug the harness and then push the rubber harness bung out to allow painting.
Cheers
John
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 12-31-2005, 11:31 PM
Gon fix it with me hammer
svandamme's Avatar
it's all quite delicate and brittle if it's the original wiring..
mine disintegrated when i got them out
Stijn Vandamme
BIMDIESELBMW116D2019
Old 01-01-2006, 01:50 AM
Non Compos Mentis
Or you could unscrew the back of the light housing and tuck it inside out of the way and leave the wiring intact. Depends on how far you want to0 strip the car down.
Old 01-01-2006, 10:15 AM
Tomy's Avatar
They get out very easy (connectors) if you have some heat on it (not too much hairdryer could be OK) when plugs get heat you could pull it out and they will get out from holes, so you will have taillights with harness as one part. Installation of those connectors are the same - you should to warm it a bit and than put in to the holes.
So my 3 cents... from experiences.
TET930 996 TT 2003 X50 996 GT3 2004
930 1988 black on black -fast...
944 TURBO S 1989 WHITE/BLACK # 1 944 TURBO S 1989 #2
911 S 1970 Targa /ex porsche werks car!
911 S 1969 Targa (under rebuild)
Old 01-01-2006, 10:39 AM
brittbolen's Avatar
thanks tommy, i just figured that out when i figured out how to remove the front wiring so I could get the fender off...
One thing, i guess I need to disconnect the oil tank level sender too since that is wired to the same harness, much like the horn is on the headlight harness.
those back side screws on the taillight assembly are not budging and i don't want to strip 'em yet...
Britt
Old 01-01-2006, 11:28 AM
