| Free minder |
				Shed for rebuilding engine
			Here is my problem: I have read the two Wayne books, I have broken headstuds and I would really like to take my 3.0 engine appart to fix that and other issues. Unfortunately, I don`t have a garage, so here are my options: #1- Sell the car as is, buy a trouble free one. I figure I could get $7-8k for my car which is running fine despite the headstuds, and reinvest ~4k to buy another SC. #2- Pay a mechanic to do the job. If he can replace headstuds, refresh the heads and install carrea tensioners for under $5k, that is an option. #3- Build a garage, then rebuild my engine. I ruled out that option, as it does not make much financial sense. Plus, my property would not look nice with a garage next to it. #4- Build a 10x12 shed at the end of my driveway, and use it to rebuild the engine. Has anyone done that? The benefit is that I need a shed anyways, and I really would like to work more on my car , as a hobby. Has anyone ever used a shed as a P-car workshop? If so, I`d love to see pictures. Sure it might be a little tight, but doable. I am seriously considering that option. Which one would you choose? Aurel | ||
|  01-01-2006, 08:22 AM |
| Slippery Slope Victim Join Date: Oct 2001 Location: Brooklyn, NY    USA
			I'd go with the shed idea.  Install lighting and heat (both portable) an engine stand, tools and a few shelves and you're done. Drop the engine outside or partially in the shed if possible, roll out, and work on the engine in the shed. Try to seal out the elements (cauling & weatherstripping). I don't think that 10' x 12' is too tight of a space at all. Good Luck and above all.........Keep the Faith!
				__________________ Mike² 1985 M491 Last edited by NY65912; 01-01-2006 at 08:51 AM.. | ||
|  01-01-2006, 08:36 AM |
| Registered |
			I'd say get a shed. With the car in here I'd didn't have much more than 10x12 at the back.
				__________________ 1984 3.2 Carrera Impact Bumpers on track: http://www.youtube.com/watch?v=C4qbFNkdD2o | ||
|  01-01-2006, 08:46 AM |
| Me like track days Join Date: Sep 2003 Location: Kirkland, WA
			Just thinking a bit here.....a shed in NJ would have quite a bit of moisture.  Parts rust easily when cleaned.  Just avoid raw ferrous metal exposure and go for it -
				__________________ - Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno | ||
|  01-01-2006, 08:47 AM |
			( P.S. 911MOT - How'd you get that plate?  Don't those 'cherished plates' go for huge $$$ in the UK - when you can get them?)
|  01-01-2006, 08:51 AM |
| Semper drive! | Quote:
 When I first read Aurel's post, I immediately thought of your setup. I remember seeing the pics you had posted a year or two ago and marvelling at how you were able to move around in there, let alone dropping your engine. I was going to post a reference to you but could not remember your name.  I only remembered that you lived in the UK. Thanks for posting this. Should be just the thing for Aurel to use. Happy New Year! Randy
				__________________ 84 944 - Alpine White 86 Carrera Targa - Guards Red - My Pelican Gallery - (Gone, but never forgotten  ) One Marine's View Igitur qui desiderat pacem, praeparet bellum | ||
|  01-01-2006, 08:52 AM |
| Registered Join Date: Oct 2001 Location: San Carlos, CA US
			Option 2 is doable, but you gotta find a decent mechanic for that. Building a shed is good if you live in California. New Jersey can get cold ... for a shed.
				__________________ Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 | ||
|  01-01-2006, 08:54 AM |
| Free minder |
			911mot, Very nice pics, Thanks. How wide was this space? You are absolutely right, if the car is inside, you end up with less working space than a shed anyways. Looks like my idea is not so stupid after all. Actually, if I was really going to do it very cheap, a 10x12 steel shed costs $259 at Sears. Throw in a 1500W space heater, 500W halogen light (which I both already have), and you`re done! Now, I will go for some nicer Shed made out of wood. Aurel
				__________________ 1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/ 2014 Cayenne platinum edition 2008 Benz C300 (wife’s) 2010 Honda Civic LX (daughter’s) | ||
|  01-01-2006, 09:03 AM |
| Registered |
			I reckon about 8 or 9ft wide, all I remember is it was A LOT wider than my last place, thats for sure...    Craig the plate was £500 from ebay, £80 to transfer
|  01-01-2006, 09:22 AM |
| Registered Join Date: Oct 2000 Location: Nor-Cal
			You don't say that it is an option in your situation, but people have rebuilt these motors in their living rooms before.  Ask RoninLB what it was like to carry his motor out of his living room, and down a flight of stairs.
|  01-01-2006, 10:00 AM |
| Free minder |
			I might have considered using my living room as an option before I got married. Now, it is definitely not an option anymore    Aurel | ||
|  01-01-2006, 10:04 AM |
| Registered Join Date: Feb 2002 Location: Central NJ
			Aurel, 10x12 might be too big in NJ. I know that in Bridgewater, NJ there is a max size of like 8x10 for sheds. Check your local laws. Also, some neighbours of mine got a very nice plastic unit @ home depot where the walls just interlock together, this thing has a window and the roof has a skylight. It is being used a pool cabana. Do you own the home? If you build the garage, could you store tha car there? It is a bigger upfront investment, but might be worth it long term. You will also have to get permits and such... Lou
				__________________ '76 911 "Moneypenny" daily driver '74 911 "JLo" IROC DE Car '03 CRV, '02 Jeep Grand Cherokee '03 Holiday Rambler Admiral SE, 30ft, 8.1l, 340HP, 455Ft# http://www.nicotra4.hpshare.net/BasketCaseMotorsports/ | ||
|  01-01-2006, 11:26 AM |
| Registered Join Date: Jan 2001 Location: So. Cal.
			The shed idea is a good option.  It wouldn't be too complicated to build one like you wanted, including a wide door in the front to get stuff in & out of.  Insulation is a possibility too.  Also, you could consider one of those protable, fabric car cover/roof things to keep your car under while working on it.  They don't cost too much and you could use it later on.
				__________________ Marv Evans '69 911E | ||
|  01-01-2006, 11:49 AM |
| Stranger on the Internet Join Date: Apr 2004 Location: Bradenton, FL
			I used a shed 25 years ago when I had my first house in Alaska. Heat it and put some lights in and you're good to go. Do you have a basement?
				__________________ Patrick E. Keefe 78 SC | ||
|  01-01-2006, 06:20 PM |
| Detached Member Join Date: May 2003 Location: southern California
			Why not get an EZ Up, like a big tent with sides? Like the one on the link below. Cheap and you can take it down when your done.  Not so good for the winter though.  this
				__________________ Hugh | ||
|  01-01-2006, 06:33 PM |
| Free minder | Quote:
 Aurel | ||
|  01-06-2006, 05:57 AM |
			I have found you can attract a couple of strong buddies if you use beer as bait. Preferrably imported beer. Pat
|  01-06-2006, 06:41 AM |
