CBRacerX's Avatar
993 P&C with 964 Block & Heads
I think I already know the answer to this, but would appreciate some confirmation. The use of 993 Pistons and Cylinders with a 964 Block, Crank, Rods and Heads would require new rods (at minimum) since the rod is smaller (thinner) on the 993.
Do I have this right?
Chris
Old 01-02-2006, 07:26 AM
Bill Verburg's Avatar
The pistons and rods need to match the crank
i.e. 964crank, 964 rods, 964 pistons or 993crank, 993 rods, 993 pistons
Bill Verburg
Old 01-02-2006, 07:31 AM
CBRacerX's Avatar
Unless I care to make custom rods for the 964 crank and the 993 pistons, eh?
Chris
https://dergarage.com
‘11 987.2 CS, '01 986S, '11 958S, '24 R1T, '87 Defender V8
Old 01-02-2006, 07:44 AM
Interesting..
So is the only difference between 964 and 993 pistons the width of the wrist pin bush space/
Ie 964 rods just need narrowing some to use the 993 P+B?
Old 01-02-2006, 09:11 AM
Originally posted by davidppp
Interesting..
I believe so, but never heard of anyone doing it that way.
Bill Verburg
Old 01-02-2006, 01:46 PM
I should add that the 993 crank is considerably more robust than a 964 crank and the the 993 rods are lighter but at least as stron as the 993 versions.
I would want a 993 lower end in my cars.
Bill Verburg
Old 01-02-2006, 02:54 PM
