993 P&C with 964 Block & Heads
I think I already know the answer to this, but would appreciate some confirmation. The use of 993 Pistons and Cylinders with a 964 Block, Crank, Rods and Heads would require new rods (at minimum) since the rod is smaller (thinner) on the 993.
Do I have this right? Chris |
The pistons and rods need to match the crank
i.e. 964crank, 964 rods, 964 pistons or 993crank, 993 rods, 993 pistons
Unless I care to make custom rods for the 964 crank and the 993 pistons, eh?
Chris https://dergarage.com ‘11 987.2 CS, '01 986S, '11 958S, '24 R1T, '87 Defender V8 |
Interesting..
So is the only difference between 964 and 993 pistons the width of the wrist pin bush space/ Ie 964 rods just need narrowing some to use the 993 P+B? Thanks David |
I should add that the 993 crank is considerably more robust than a 964 crank and the the 993 rods are lighter but at least as stron as the 993 versions.
I would want a 993 lower end in my cars.
