bondo looks white - at least that I've seen. could be brown -- don't worry it will be very obvious that whatever it is is NOT metal when you are doing it.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
Here are the 2 rust spots in the lower front corner of the door. All the bondo has been scraped away, leaving these spots, which are not much bigger then the tip of my pinky finger
And the progress through today, no scraping tonight. Tomorrow I'll do more disassembly, fender off, lights out, door handles off. Britt |
The bondo, seems very thin, and under it i can't see any obvious dents...
Britt |
I don't know why anyone would attempt this without the proper tools.
87 Carerra Coupe 04 GMC Yukon 07 Mazda 3 00 GMC Sierra |
Funny, I would have guessed that the brown stuff is glazing compound. It goes on REALLY thin, but hardens like iron compared to bondo. Really does the job of filling scratches and pinholes though.
Chris
1986 Carrera Coupe 1987 Dodge W250 2000 Volvo V70 2007 Land Rover LR3 |
it could be glazing compound, it is a much harder to remove than the paint, MUCH harder.
Britt |
I was just looking at one of my cars (not a p-car) that I painted in 2002. It has bubbles in some of the spots I repaired. I come from the fiberglass side of bodywork (Corvettes) and part making, so at the time, I didn't take enough precaution. I can't emphasize enough how persistent rust is. It won't stop if any trace is left. It truly is a cancer. |
Never assume that a PO did work correctly... who knows what they filled holes with -- could by Play-dough, Silly Putty, Plastic Wood, sawdust mixed with Elmer's glue....
Southern Class & Sass
Dixie Bradenton, FL 2013 Camaro ZL1 |
Make sure that you wipe down the panels, particularly the formerly rusty areas with a phosphoric acid rust converter, such as Ospho. When you think you've made it to bare metal, realize that at a microscopic level, there's still rust. The Ospho converts the red gamma hematite (rust) to iron phosphate. Only then can you be sure that it will not come back...
Just make sure to SCRUB the residue off the panel when you wash for paint prep. Although the product claims that the post-treated surface improves paint adhesion, it's a lie. The primer sticks to it, but because the stuff has the consistency of hard wax, the surface cannot be made smooth. $2.00 worth of words to give $0.02 worth... Chris
Chris, my mechanic has been advising me on how to do this, and also recommended Ospho. I picked up a bottle.
You're talking about the Ospho residue? I was told to spray it on, let it sit a few minutes and then wipe it off. The car might not get painted immediately, and certainly not by me, so i'm sure they'll be sanding it then... Milt, do you think, from the photos, that a wire brushing and a treatment like ospho is good enough, or do i need to do something drastic like cut out the corner of the door? I guess it depends on what the inside of the door looks like, doesn't it? thanks guys, this is all very helpful! Britt, who knows very very little |
Looking back, I've tried a bunch of rust "treatments" POR-Ospho-etc. and never been able to truly kill the stuff. Rust never sleeps, the only sure, long term method is too cut it out, weld in a new piece, and start fresh. IMO. But that brings a whole new set of issues, especially if your not great with tig or mig, or straightening sheet metal. For the low dollar resto, baking powder blast, immediately seal with POR 15, and get some paint on it asap has worked on my old bikes pretty reliably, Good Luck!
Mike 1995 993 Polar Silver cab 86 ROW cab, gone but not forgotten. 1948 Indian Chief 1989 FLHS Too many old british race bikes. If it doesnt leak, it must be out of oil ! |
What's Facebook?
I too prefer the razor blade method. Never done a complete car though. I round off the corners of the razor blade and this drastically reduces the "digs" into the metal.
Turborat "’Cause every once in while, the lion has to show the jackals who he is” 1979 911 SC - 2100 LB track rat 1986.5 928 5-Speed - 36,000 miles 2001 330Ci |
sweet, i was thinking of trying to round off the corners of the blades!
Brit |
Why not spend the $500 and have it media blasted ?? that's what the pros do..??
"Todd" 98 Tahoe ,2007 Saturn Vue 86 930 black and stock, 80 930 blue tracdog 91 Spec Miata (yeah I race a chick car) "life"ll kill ya" Warren Zevon |
So I considered the media blasting option, and discussed it with my mechanic who's been helping me prep the car for paint, and, well, i wanted to do as much stuff myself as possible 1) to have something to do 2) save some money, and 3) and well, i'm not going to take the whole car apart, so I might have a lot of media rolling around for, well, forever...
Anyways progress is good, i'm probably 1/3 stripped at this point... found a little bondo in the bottom corner of the quarter, but nothing bad so far... Britt |
Hi there.
That door will need nothing less than a new lower portion. The work involved in putting things right first time is far less then doing it twice. Ask me how I know this! Kind regards David |
a stripper's work is never done...
Progress through last night...
Now there is some bondo here, kinda thick... should I scrape it all out, or leave it as a starting place for the body shop? You can see one spot where i scraped into it... Sometimes we get a little bit optimistic, you know, like when you see a longhood on ebay and you _believe_ the 'no rust' description, well I had my moment of extreme optimism... And a word to the wise, don't bother trying that "no fumes, indoor safe" paint stripper crap... it couldn't strip WET paint. Now I'm left with a layer of paintless primer that won't budge with a razor blade... Britt |
