randywebb's Avatar
bondo looks white - at least that I've seen. could be brown -- don't worry it will be very obvious that whatever it is is NOT metal when you are doing it.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 01-06-2006, 09:43 PM
brittbolen's Avatar
Here are the 2 rust spots in the lower front corner of the door. All the bondo has been scraped away, leaving these spots, which are not much bigger then the tip of my pinky finger
And the progress through today, no scraping tonight. Tomorrow I'll do more disassembly, fender off, lights out, door handles off.
Britt
Old 01-06-2006, 09:45 PM
brittbolen's Avatar
The bondo, seems very thin, and under it i can't see any obvious dents...
Britt
Old 01-06-2006, 09:47 PM
I don't know why anyone would attempt this without the proper tools.
87 Carerra Coupe
04 GMC Yukon
07 Mazda 3
00 GMC Sierra
Old 01-07-2006, 12:53 PM
Zeke's Avatar
Originally posted by brittbolen
This will sound like a silly question... what does bondo look like when scraping a car? Is bondo this very dry brown stuff i'm finding in spots on the door? I had thought it was primer, but then i discovered it wasn't everywhere...
Britt
Body fillers can be a number of different colors and shades. The most common are pinkish and blue. Reddish brown is a popular primer. Bondo (body filler) dissolves somewhat with paint stripper, softens with pretty high heat, and sands like wood.
Old 01-07-2006, 02:34 PM
AtomicDog's Avatar
Funny, I would have guessed that the brown stuff is glazing compound. It goes on REALLY thin, but hardens like iron compared to bondo. Really does the job of filling scratches and pinholes though.
Chris
1986 Carrera Coupe
1987 Dodge W250
2000 Volvo V70
2007 Land Rover LR3
Old 01-07-2006, 03:22 PM
brittbolen's Avatar
it could be glazing compound, it is a much harder to remove than the paint, MUCH harder.
Britt
Old 01-07-2006, 03:32 PM
Zeke's Avatar
Chris
Good point. Britt, you've got to get that rusty metal out of the door or you will have bubbles in your new paint in time. Not that much time, either.
I was just looking at one of my cars (not a p-car) that I painted in 2002. It has bubbles in some of the spots I repaired. I come from the fiberglass side of bodywork (Corvettes) and part making, so at the time, I didn't take enough precaution. I can't emphasize enough how persistent rust is. It won't stop if any trace is left. It truly is a cancer.
Old 01-07-2006, 03:52 PM
randywebb's Avatar
Never assume that a PO did work correctly... who knows what they filled holes with -- could by Play-dough, Silly Putty, Plastic Wood, sawdust mixed with Elmer's glue....
Old 01-07-2006, 03:57 PM
Southern Class & Sass
Dixie's Avatar
Start over at page one. He IS using the proper tool...
Dixie
Bradenton, FL
2013 Camaro ZL1
Old 01-07-2006, 04:09 PM
AtomicDog's Avatar
Make sure that you wipe down the panels, particularly the formerly rusty areas with a phosphoric acid rust converter, such as Ospho. When you think you've made it to bare metal, realize that at a microscopic level, there's still rust. The Ospho converts the red gamma hematite (rust) to iron phosphate. Only then can you be sure that it will not come back...
Just make sure to SCRUB the residue off the panel when you wash for paint prep. Although the product claims that the post-treated surface improves paint adhesion, it's a lie. The primer sticks to it, but because the stuff has the consistency of hard wax, the surface cannot be made smooth.
$2.00 worth of words to give $0.02 worth...
Chris
1986 Carrera Coupe
1987 Dodge W250
2000 Volvo V70
2007 Land Rover LR3
Old 01-07-2006, 06:25 PM
brittbolen's Avatar
Chris, my mechanic has been advising me on how to do this, and also recommended Ospho. I picked up a bottle.
You're talking about the Ospho residue? I was told to spray it on, let it sit a few minutes and then wipe it off. The car might not get painted immediately, and certainly not by me, so i'm sure they'll be sanding it then...
Milt, do you think, from the photos, that a wire brushing and a treatment like ospho is good enough, or do i need to do something drastic like cut out the corner of the door? I guess it depends on what the inside of the door looks like, doesn't it?
thanks guys, this is all very helpful!
Britt, who knows very very little
Old 01-07-2006, 07:34 PM
Zeke's Avatar
You got it. Much of the work is done "behind the scenes." That was my problem, I didn't address the backside thoroughly enough. Anything that goes completely thru the panel has to be cut out, IMO.
Yeah, but you're here asking. That's an excellent way to achieve a great job. You've got dozens of capable advisers, but none looking over your shoulder.
Old 01-07-2006, 07:51 PM
Looking back, I've tried a bunch of rust "treatments" POR-Ospho-etc. and never been able to truly kill the stuff. Rust never sleeps, the only sure, long term method is too cut it out, weld in a new piece, and start fresh. IMO. But that brings a whole new set of issues, especially if your not great with tig or mig, or straightening sheet metal. For the low dollar resto, baking powder blast, immediately seal with POR 15, and get some paint on it asap has worked on my old bikes pretty reliably, Good Luck!
Mike
1995 993 Polar Silver cab
86 ROW cab, gone but not forgotten.
1948 Indian Chief
1989 FLHS
Too many old british race bikes.
If it doesnt leak, it must be out of oil !
Old 01-07-2006, 08:00 PM
What's Facebook?
turborat's Avatar
I too prefer the razor blade method. Never done a complete car though. I round off the corners of the razor blade and this drastically reduces the "digs" into the metal.
Turborat
"’Cause every once in while, the lion has to show the jackals who he is”
1979 911 SC - 2100 LB track rat
1986.5 928 5-Speed - 36,000 miles
2001 330Ci
Old 01-07-2006, 08:12 PM
brittbolen's Avatar
sweet, i was thinking of trying to round off the corners of the blades!
Brit
Old 01-07-2006, 08:27 PM
9dreizig's Avatar
Send a message via AIM to 9dreizig
Why not spend the $500 and have it media blasted ?? that's what the pros do..??
"Todd"
98 Tahoe ,2007 Saturn Vue
86 930 black and stock, 80 930 blue tracdog
91 Spec Miata (yeah I race a chick car)
"life"ll kill ya" Warren Zevon
Old 01-08-2006, 06:24 AM
brittbolen's Avatar
So I considered the media blasting option, and discussed it with my mechanic who's been helping me prep the car for paint, and, well, i wanted to do as much stuff myself as possible 1) to have something to do 2) save some money, and 3) and well, i'm not going to take the whole car apart, so I might have a lot of media rolling around for, well, forever...
Anyways progress is good, i'm probably 1/3 stripped at this point... found a little bondo in the bottom corner of the quarter, but nothing bad so far...
Britt
Old 01-08-2006, 10:30 PM
Hi there.
That door will need nothing less than a new lower portion.
The work involved in putting things right first time is far less then doing it twice.
Ask me how I know this!
Kind regards
Old 01-09-2006, 04:31 AM
brittbolen's Avatar
a stripper's work is never done...
Progress through last night...
Now there is some bondo here, kinda thick... should I scrape it all out, or leave it as a starting place for the body shop? You can see one spot where i scraped into it...
Sometimes we get a little bit optimistic, you know, like when you see a longhood on ebay and you _believe_ the 'no rust' description, well I had my moment of extreme optimism...
And a word to the wise, don't bother trying that "no fumes, indoor safe" paint stripper crap... it couldn't strip WET paint. Now I'm left with a layer of paintless primer that won't budge with a razor blade...
Britt
Old 01-13-2006, 08:08 AM
