70 911E using lots of gas?
I have been working on this project for a while and have recently been able to really start to drive it. It starts and seems to run very well. I am truing to figure out why I am burning through gas at a very fast rate. I have probably gone about 20 miles and had the car idle for a bit but it has burned about 6 gallons of gas, it seems to be pretty consistent. I have not been able to find any gas leaks and so I am wondering what I should be looking at. The oil seems fine and once the car is running no real smoke to speak of. I have a little backfiring on decel because I think the RPM transducer is not working (could that cause that much gas to be used?) Any suggestions would be great.
1989 Cabriolet
1970 911E Sold
Old 12-07-2007, 05:19 AM
MFI and good mileage are an oxymoron. they're a rich running system. not as bad as yours of course. is your preheat hose attached from the heat exchanger to the pump t/stat? won't lean out if it isn't. get it on a gas analyzer and see what you have. they need to run on the rich side as mentioned, like 6% idle and mid range or you will have idle and transition problems.
206 637 4071
Old 12-07-2007, 05:41 AM
Scott at Pelican Parts's Avatar
My '71 E runs really well. For comparison, I get about 12mpg in the city, and about double that on the highway.
Old 12-07-2007, 05:44 AM
Zeke's Avatar
20 miles is not enough to gauge whether you are depositing some gas in the oil. And, when the oil is warm enough, it evaporates the gas. So one run at 20 mi has two things working against you AFA diagnosis. Do as JW say and fine out the mixture first. Also, check your plugs. Shoot, check you entire ign sys to be sure you're spot on.
Old 12-07-2007, 07:59 AM
dtw dtw is offline
GAFB
Check, Measure, Adjust. Do not pass go, do not collect $200, go straight to CMA.
http://www.pelicanparts.com/techarticles/911_MFI/MFI_check_measure_adjust.zip
Several BMWs
Old 12-07-2007, 08:21 AM
webbers are in order perhaps...... I never could get the MFI right on my early cars
Robert Breshears
bob@appbiz.com
310-834-3600
Owner Appled Business Concepts
Old 12-07-2007, 09:16 AM
Bug Eating Member
frogger's Avatar
NO! And Webers are no gaurantee if they are worn. The Check Measure Adjust (CMA) procedure is great, but it requires you follow along faithfully through all the steps. Backfiring sounds like it's too rich, but that could be because of injection pump adjustments or the microswitch being out of adjustment (or defective) or other problems in you setup. Once again, use CMA to set it up. Post questions here if you aren't sure of something and you'll receive plenty of help. A well-tuned MFI engine is a sweet thing. Mine gets around 20mpg on the highway and pulls strong. Good luck.
Old 12-07-2007, 09:30 AM
912 Geek
There's nothing as sweet as a nice MFI engine. My '70 911E once had a brief problem running super-rich, and it was simply a broken clip on the rod inside the FI pump. That was 20 years ago, so I can't recall the specifics, but it was an easy fix. Hie thee to a good MFI mechanic.
Old 12-07-2007, 02:34 PM
Grady Clay's Avatar
David,
That kind of fuel consumption most likely is the cold running thermostat being full-on all the time. That usually is because the heat from the left heat exchanger isn’t getting to the thermostat to timely turn it off.
Is the thermostat very hot to the touch after some driving? Be careful, it can burn you.
Of course there can be other causes and various malfunctions, the result is the same.
Regardless of the cause, this fuel rate must be diluting the oil with gasoline. Smell in the oil fill. How thin is the oil on the dipstick? If you even suspect serious oil dilution, change the oil asap.
The issues with gasoline diluted oil are very poor lubrication (first to go is the cam-to-rocker) and (most important) when the engine gets hot, it boils off the gas leaving not enough oil to lubricate the engine. Rod bearing failure soon follows $$,$$$.00!
Frank, I’ll give you a call in a few.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 12-07-2007, 04:25 PM
gulf908's Avatar
....webbers are in order perhaps......
this is NOT an option...
The MFI WDP will come to get you Bob....we know where you are....
Cheers,
Dennis.
...you should have lots of local help in your area ?...
The 914-6 from my 'Lotto'garage has finally arrived.
1971 911S 2.2.
1975 Carrera Targa (ROW) - missed.
One of us is fast becoming a valuable antique.
Old 12-08-2007, 12:40 AM
Tree-Hugging Member
Jim727's Avatar
We have a WDP??? I knew I joined a cult, and was thinking we *needed* a WDP.
Cool. Sign me up!
Politicians should be compelled to wear uniforms like NASCAR drivers, so we could identify their owners.
Old 12-08-2007, 09:41 AM
Grady Clay's Avatar
Excuse lame old me, what is WDP?
I agree, too many MFI owners opted for carburators when their MFI could have been properly brought into specification. This was mostly pre-Pelican. Today many are reconfigurating back to MFI.
I still want to know that your thermostst is hot.
Best,
Grady
Old 12-08-2007, 10:49 AM
Tree-Hugging Member
Jim727's Avatar
Grady -
WDP = World Domination Plot.
Having just converted my 2.2T to a 2.2E with MFI I'm learning why MFI has a cult-like following. It's intoxicating. Even though it's not completely dialed-in yet, I love it and I don't think I've turned the radio on since the conversion.
Jim
Old 12-08-2007, 11:01 AM
304065's Avatar
WE walk among you.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 12-08-2007, 01:09 PM
Tree-Hugging Member
Jim727's Avatar
YES!!!
Mine has 2 solenoids - can I still play???
We need stickers.
Jim
Oops - sorry. Back to fuel economy.
Old 12-08-2007, 01:25 PM
Bandwidth AbUser
Jim Richards's Avatar
Jim R.
Old 12-08-2007, 01:54 PM
Tree-Hugging Member
Jim727's Avatar
Jim -
w/ 2.7RS-spec "lump" ??
Old 12-08-2007, 02:53 PM
Bandwidth AbUser
Lump is good. Run's fine, Jim.
Jim R.
Old 12-08-2007, 03:10 PM
gulf908's Avatar
...Excuse lame old me, what is WDP?...
Grady,
I always thought of you as the Grand Wizard of this MFI cult....
Cheers,
Dennis.
1971 911S 2.2.
Old 12-08-2007, 10:13 PM
Grady Clay's Avatar
Dennis,
While I may know a little bit about original MFI, I'm not always up on the current 'dingo, lingo, logo'
The good news I'm not embarased to ask. Just dumb ol' me.
I never thought of MFI as 911 SCWDP like.
Best,
Grady
Old 12-09-2007, 10:05 AM
