RETIRED
What was your cheapest but labor intensive fix?
My recent 930 tranny disaster.....had to pull the drive train due to 1st,2nd and reverse gear running away and hiding.....
I disassembled the trans case expecting shift forks to be loose or a foreign object crammed in someplace.....NOTHING..... Picked up the rear cover plate and found that a $.75 circlip had popped of the reverse idler gear...... 100 bucks worth of Swepco and a gasket kit and it was fixed....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
In the shop at Pelican
broken ball pivot for the T.O. bearing arm on a 901 tranny
Jared,
If you are referring to the '70-'71 type "911" gearbox, I agree entirely. Since you have to pull the engine/tranny assembly and then separate them to get at the ball pivot, the "while we're in there" stuff can also be expensive and time consuming.
Sergio The GT Lid Whisperer PCA 42yrs - National DE Instructor / Ex-RGruppe #197 '19 718 Cayman S (9th Porsche/1st with PDK) '14 Subaru Forester XT (Porsche support vehicle) |
abit off center
86 Carrera. Starter ring gear "Free" because its still hanging on the garage wall after the engine is back in the car. Labor? well lets not talk about that!
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
Charlie 1966 912 Polo Red 1950 VW Bug 1983 VW Westfalia; 1989 VW Syncro Tristar Doka |
Bland
06 Cayenne Turbo S and 11 Cayenne S 77 911S Wide Body GT2 WCMA race car 86 930 Slantnose - featured in Mar-Apr 2016 Classic Porsche Sold: 76 930, 90 C4 Targa, 87 944, 06 Cayenne Turbo, 73 911 ChumpCar endurance racer - featured in May-June & July-Aug 2016 Classic Porsche |
abit off center
Crotchety Old Bastard
How about a nickel sized hole poked in a case?
Fix was a 30 second weld. Cost was a complete split case teardown and rebuild. I redefined Turettes.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
Kantry Member
Re-indexing the rear torsion bars.
When I got the 'old E', the muffler was almost dragging in places. Can't have that, there are bumps on the road in Nova Scotia. So, with the information and advice on this board, I went at it. After a day and 1/2, I had both sides the same height (and no longer scraping on driveways), but it was higher than I wanted. (Darn thing looked like a ralley car!) I drove it for a few weeks that way then went back at it again. The second time was much easier, I was able to do the job in an afternoon. Total spent on parts, $0.00 Bandaids, 5 Satisfaction, priceless. Les
Best Les My train of thought has been replaced by a bumper car. |
Slumlord
Main seal, leaked beacuse my 2.7 case was slightly oval. Had to remove engine, (twice), machine the outer diameter for the seal, make a 0.010" sleeve, and press in a new seal.
About $5.00 material, and 40 hours of bu11$h!+.
84 Cab - sold! 89 Cab - not quite done 90C4 - winter beater |
wrong sized spline on the clutch disk
-Matt 1985 Targa |
suspension refurb
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
