83 SC won't start
So what's up? Just bought my first Porsche (1983 911 SC Cab).
I drove to golf this AM, got back in the car & drove home - all okay. One hour later car would not start - just a couple clicks from up front - no starter noise etc. - reset the relays at the fuse box (random guess because of the clicking noise) and car started right up. Went to get smogged - turned off car - restarted for the smog guy, but after smogging same problem as before - would not start - we pushed it to get it started and it started right up. Got home okay, turned off the ignition and then tried to restart, but no luck - same clicks from up front but no indication that power was getting to the starter - tried to jump start with a battery pack and would not start. The battery shows 12.35 volts.
When connecting the negative terminal I got some small arcing and thought this not to be correct ... so what do I do now?
Thanks for your help!
Old 05-14-2007, 07:53 PM
Some additional info - after above post, I reconnected the battery pack and the car started right up! Only thing different is that I connected neg battery pack to chassis and not to the battery - also, another hour or so had passed since last start attempt - maybe something is heat sensitive? Or what?
Old 05-14-2007, 08:16 PM
brett25's Avatar
I have this problem too. It could be due to the heat. Check on pelican for the starter relay kit. Its a fix, however, the cause has something to due with there not being enough current going to the starter when the components get hot. The ground strap is a place to start.
After some time the car cools down enough and then it starts again
1980 911 SC Coupe
1987 944
Old 05-14-2007, 08:21 PM
Mothy's Avatar
Send a message via AIM to Mothy
Had the same thing happen to me recently - especially if you tried to restart after being off for only say 5 or 10 minutes. No clicks like when you get a low bettery - just silence when you turn the key, but with all the lights dimming like its trying to start.
Turned out it was the starter solenoid - gets stuck when its old with the buildup of dust etc. from the starter motor brushes.
Had the starter reconditioned (much cheaper than a new one) and have not had an issue since.
Tim
Swapped my WRX Sti MY02 for a Porsche 911SC '83
Keep buying parts to make it look older.
Mid life crisis is now in its 12th year.
Old 05-14-2007, 08:55 PM
SCWDP911's Avatar
sub'd
Shane
- 1984 928S
Old 05-14-2007, 09:19 PM
Bad starter. Replace that sucker/
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 05-14-2007, 09:22 PM
Thanks for the help!
What about the arcing when I reconnect the negative terminal to the battery - what is causing this? Or is this normal?
Old 05-15-2007, 07:31 AM
Two Tone's Avatar
Yes, that's normal. Thats why it's recommended that when boosting a vehicle, the last connection made should be the negative clamp made to the chassis instead of the neg. post. This way, any sparks that occur are away from the discharged battery, which may be venting hydrogen.
I rarely worry about it though.
1977 911S with a 78 SC Engine
Old 05-15-2007, 06:19 PM
