idling too long
Hello,
anyone ever have trouble letting their 911sc idle too long and then the car dies when trying to take off. It was raining so maybe someting got wet, but when I let it idle for too long it will not run, I stalled on the interstate. The owners manual states not to let the car warm up idling, anyone know the reason.
Thanks, Kevin
Old 01-06-2006, 11:35 AM
durn for'ner
livi's Avatar
Welcome (from Sweden)!
Canīt say whats going on with your car but any engine suffers more from running cold and idling till warm takes longer than driving gently.
Or so I understand it at least..
Markus
Resident Fluffer
Carrera '85
Old 01-06-2006, 11:51 AM
mschuep's Avatar
Reasoning for not idling to warm up is a dry sump issue, idling no good for dry sump.
-Matt
1985 Targa
Old 01-06-2006, 12:57 PM
Gon fix it with me hammer
svandamme's Avatar
idling to warm up is not a dry sump issue, it's in every car manual i've seen so far, be that water pumpers, air cooled engines or even diesels...
reason for not idling to warm up is that it justs doesn't warm up fast enough...and you do want to get to operating temperature as fast as possible (withing reason and without abusing the cold engine that is )
that also why there is a thermostat on the cooling plumbing (oil for air cooled, or water for watercooled)... because untill it's warm enough , the coolant should not be cooled, because engine manufacturers want to reach operating temp asap.
idling does not put a load on the engine, without a load, the temp doesn't go up quick enough
and engine will heat up faster in 5 minutes driving , than in 10 minutes of idling
http://www.tocmp.com/manuals/Buick/1963/BreakIn/pages/union76-7_jpg.htm
that's a 63 Buick, and i'm sure it doesn't have a dry sump, and i'm sure it's a water pumper
968 manual
http://www.cannell.co.uk/Boxster_Manuals/986%20owners%20manual.pdf
page 62 ... "Do not let the engine idle to warm up "
Stijn Vandamme
BIMDIESELBMW116D2019
Old 01-06-2006, 01:13 PM
durn for'ner
livi's Avatar
So, I guess we are in full agreement there, Stijn.
Markus
Resident Fluffer
Carrera '85
Old 01-06-2006, 01:37 PM
svandamme's Avatar
i'm sure there will be another thread in a month or 2 where this point will come up ...
going back to the initial problem ... probably some thing with CIS , mixture bit off, vacuum leak , or something else, the CIS guru's can comment on that
running some Techron on a CIS system also has very good results... cleans things out ....
Stijn Vandamme
Old 01-06-2006, 01:45 PM
mschuep's Avatar
Well, after some more looking around, I think I was mistaken. I would swear I had read that dry sump was main reason not to do this (obviously there are other reasons like Stijn mentioned). My apologies, I am the jackass today.
-Matt
1985 Targa
Old 01-06-2006, 02:18 PM
svandamme's Avatar
not a jackass, besides i think i'm a bit on edge here, bit to harsh, spent to much time on OT...
my apologies
Stijn Vandamme
Old 01-06-2006, 02:20 PM
Nine9six's Avatar
After three reads, only one word comes to mind...
"punctuation!"
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 01-06-2006, 02:46 PM
svandamme's Avatar
996? how do you say punctuation in swedish?
Stijn Vandamme
Old 01-06-2006, 02:49 PM
durn for'ner
livi's Avatar
Alright then. I had to read it three times myself. No luck.
I meant what Stijn explained in more words, anyway.
Give me a brake. Its past midnight here in Viking country. I am a durn for'ner and I donīt know the first thing about Porscheīs.
Markus
Resident Fluffer
Carrera '85
Old 01-06-2006, 04:16 PM
Designer King
Paulporsche's Avatar
I heard a long time ago that prolonged idling puts undo stress on engine bearings since the idle speed is constant. I'm not sure if that is true, though.
One thing that is true, it wastes fuel and increases pollution unnecessarily.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
mkimber's Avatar
Let me add to the confusion. Here's the thread when I posed a similar question back in October.
Long idle time...Poor performance
Michael
1987 3.2 Carmine Red Carrera
1995 Midnight Blue 993 C4
1957 Silver Speedster Outlaw (replica)
Old 01-07-2006, 08:25 AM
svandamme's Avatar
untill somebody can tell me some real technical information as to WHY idling would be bad for a dry sump, i'll keep calling it BS.
the point about warming up the engine while driving , and not idling is all about getting to operating temp as quickly as possible (withing reason , no redline with a cold engine).. and this is not a dry sump or aircooled thing, this is a general thing for all combustion engines...
i can't imagine that Porsche would produce cars, that can't take 10 minutes of idling , i'm sure there were traffic jams and other situations why engines would be left to idle back in the sixties and seventies
i cannot imagine, how a dry sump would run into trouble because of idling , the oil pump scavenges the sump, chucks the oil in the tank
and at the same time , build oil pressure to lubricate the whole engine
at idle , the engine is designed to provide enough of both, scavenging & lubricating. so other than oil circulation , what would be special about a dry sump ????
Stijn Vandamme
Old 01-07-2006, 08:46 AM
RETIRED
Joe Bob's Avatar
Dunno...but in California, it's "Bite me".....
2012 ML350 3.0 Turbo Diesel
Oh Haha's Avatar
So do you guys that drive 911's year round just freeze your a$$ off until the car heats up in winter conditions? I don't, but my Vibe sits out and I start it when the temp is below 20 in the morning. I let it run while getting my road coffee and taking care of the doggie.
In regards to 911 engines, does the no idling deal only apply for a cold engine?
Pacific Blue
Wayne
Old 01-07-2006, 09:04 AM
durn for'ner
livi's Avatar
OK, so lets say we agree that running a cold engine is more harmful than running a hot engine. Generally speaking. Right ?
Hence, on upstart from cold, the engine will reach healthier temps faster. Thereby shorten the harmful running period. OK, but..
.. disregarding the time frame - will not idling per se put less stress on the engine than higher driving RPMīs. Even at 2k the friction energy should be much worse than at say 800 idling.
No ?
Markus
Resident Fluffer
Carrera '85
Old 01-07-2006, 09:16 AM
svandamme's Avatar
it's not about the RPM , it's about having a load on the engine
just revving the engine higher on a cold start will not make that much difference from just idling, it's the driving off , and loading the engine
same reason why folks need to drive the engine and brake on the engine during engine break in time...
the problem with a cold engine is not friction wear , the problem is that everything is designed with tolerances, the engine components all have tolerances with heat expansion in mind.... so untill the engine is warmed up , everything is out of spec, hence the requirement to get to operating temp asap.
now if you leave an engine to idle and warm up , it will take 10 minutes if at all it reaches optimal temp
if you drive, the thing slowly , don't rev to much , but do drive
it will be warmer after 5 minutes, then 10 minutes of idling.
try it , i have , it's no joke , that is the way it behaves
for testing purposes , try it on a winter day , that's when the differences is the most noticable, no point comparing it on a scorching hot day , that's an outside variable heating up the car...
look , if you don't believe my explanation , fine , i don't work for Porsche or any other car company , but the old Buick Manual says don't do it , the modern Boxster manual says don't do it... i remember a thread about the same thing where some one posted a link to a 3.2 carrera manual , and that one said , don't idle to warm up
it's no coincidence if you ask me , and if you want a fully technical explanation as to why , guess you'll have to call the manufacturers
but it's not a dry sump issue , the Buick doesn't have one , neither does a Boxster. or a Diesel engine for that matter ( and my old Tdi did have the same comment in the manual )
Stijn Vandamme
Old 01-07-2006, 09:29 AM
durn for'ner
livi's Avatar
I am with you, Stijn, as far as the shorter cold period the better. But time aside, will not putting load (driving) on the cold engine be more detrimental than not (idling)?
I believe you are right and the cold-period shortening by driving it hot is logical.
But all things equal, I still donīt grasp how it would be less harmful putting more load on a cold engine.
Then again, I am certainly no engineer. Just curious.
Markus
Resident Fluffer
Carrera '85
Old 01-07-2006, 10:28 AM
svandamme's Avatar
my guess is , that , with things cold, and out of spec
there is more vibration , more things moving in ways they shouldn't be moving.... and that's the thing that causes exessive wear
as it warms up, things expand, tighten up and eventually settle down in a normal running condition...
it's very noticable , a cold engine shudders , shakes , smokes, rattles
a warm engine doesn't
Stijn Vandamme
Old 01-07-2006, 10:49 AM
