I like the way you think.
“If you want to win anything- a race, yourself, your life- you have to go a little berserk” - Dr George Sheehan. “Happiness is different from pleasure. Happiness has something to do with struggling and enduring and accomplishing.” - Dr George Sheehan. |
The only thing better might be a /30 which is what I bought ,
Friends of Warren
I'll try... The G50/31 is the transmission that came with the 993 Carrera RS. It is a 6-speed transmission with close ratios. For me it was the perfect choice. Rebuilding my G50 with short ratios would have been expensive. Plus the "special" gears that you have avaliable in the market place are fabulous for racing but noisy for a street car. The G50/31 instead was build by Porsche with the dual utilization in mind. The syncros are upgraded from the standard 993 transmission (G50/20 and G50/21) and the ratios are closer. It also comes with an LSD (i think we'll be able to change the locking properties... we'll need to check that). These are the ratios of the transmission 1st = 3.154 2nd = 2.00 3rd = 1.522 4th = 1.242 5rd = 1.024 6th = 0.821 R&P = 3.444 With my engine (assuming redline @7,500) and my rear tires (305/35-17) these are the top speeds in gear 1st = 52 2nd = 82 3rd = 108 4th = 132 5th = 160 6th = 200 And these will be the RPM drops 1-2 2,734 2-3 1,787 3-4 1,375 4-5 1,312 5-6 1,487 Should be pretty sweet... Bill did I miss anything? |
Friends of Warren
Check this link for more infos about the 993 transmission ratios
http://www.ultimabuild.com/transmission.htm And yes, Bill gave me the heads up on the transmission I ended up buying! He's always there when I need to spend a little more money
Paul Guard has the edge in that and the strength deptartment. i'll run the #s through my gear program for you
like I said that was going to be mine, I got the info courtesy of Bill H., who apparently likes to keep a very low profile but who is also building a very nice 993.
Friends of Warren
We'll swap it when the Porsche one lets go. |
Good work fellas! VERY nice tranmission and information. Look for the gearing calculations - will be interesting!
Doug
1971 RSR - interpretation |
Re: Re: Little update
Matteo,
WOW - what is that steel tubing bridge? A jig for welding in the camber plates? Holy smokes, that's a serious apparatus. Did they make that at their shop OR buy it? Doug [/B][/QUOTE]
Friends of Warren
Re: Re: Re: Little update
Another one of their expertise is building roll cages. There is a long thread on the racing forum about their approach. Zuffenhaus - a rallye approach to cagework I am going to have them build me a custom bolt-in roll bar. |
An interesting project. I have a '75 that weighs about 1950 and has a 3.8 single plug making about 360 bhp. Uses a 915. All likely a fraction of the cost of this project...
I drive it on the street, but it is not really in the "daily driver" category... I can tell you that when I do drive it on the street, it is... somewhat fun!
Mike PCA Golden Gate Region Porsche Racing Club #4 BMWCCA NASA |
wow...hate to ask a dumb question, but i've never seen anything like that part from smartracing. is it for more than rigidity?
ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008 www.friendsofwarren.com 1990 964 C4 Cabriolet (current) 1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold) |
Here is what it looks like:
Assuming that the rear tires are ~25.6" tall
here's what you trans looks like
Location: San Francisco, USA, Stockholm, Sweden or Playa del Carmen, Mexico
Your crazy...... this will be the second comming of christ!
PRAISE THE PORSCHE GODS!!!! You rock, keep up the awesome work!!!!
Edward Larsen - Student life sucks... Carbon Black 1977 911S 2.7 with Strosek Mega body CD silver 2002 Ford Focus SVT |
Sports Purpose 911 Driver
this is becoming one of my all time favorite threads, nice work! Now my parts bill doesn't seem so bad... ;-)
James Shira R Gruppe # 271 1972 911 Coupe 3.8 RS ‘nbr two’ 1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie' 1955 356 Pre A Coupe ‘old red’ 1956 356A Emory speedster build in progress |
Friends of Warren
Elf, Edward, James... thanks for the thumbs up!
Mike... there will always be a way to do something better and cheaper... that's the challenge that we all take upon us. Your carlooks fantastic and by the sound of it it's a phenomenal 911! ![]() Bill thanks for running the transmission on your program! Awesome... After all I was not too far away in my1st hestimate! Bigchill The transverse tubing is nothing to do with the Smart Racing towers... It's a tool Zuffehaus will use to weld the towes in... I think! |
Well... make sure you have an ample budget for rear tires!
By the way, the builder of my car has basically the same thing (about 1950 pounds) with a 3.8 tt motor making about 700-750 bhp at 1 bar or so.... It too has a license plate and he drives it to and from work from time to time... I am sure that's fun!
Matteo:
I caught this thread late, looking at the jugs, the inner wall seems unusually thin; is this the max diameter you can go with the 993 case? j.p. |
