P.S.: it seems like in the end, you wouldn't have to adjust to a different exterior color!
I'm in heaven, when I drive my nine eleven... |
What is different/better about the 935 suspension?
What does it allow you to do?
Paul 1980 911SC Targa - Sold 1972 914 - Sold |
this is awesome ! I know the feeling, keep the faith !
http://www.mybuildgarage.com/author/carreraboy |
Matteo,
very nice project. It seems like money for sure isn't an issue or a limiting factor in this built. What is the entire budget you have planned for this? Just adding up a fully built 3.9 engine with MOTEC, massive tub mods, full 935 suspension, paint, new donor tub, etc. I am wondering if you could almost buy a 997 cup car outright instead.... Keep us posted with lots of pictures on progress. Cheers, Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 |
Friends of Warren
As per the advantages the main benefit is adjustability. Camber, caster, track width can be easily set. Also you get rid of the cross member as the ERP has its own. The arms are longer and the pivo point is raised to improve camber and reduce anti-dive tendencies under braking. Will I take full advantage of this? I doubt it.. at least initially... But it's there and I can only get better. These are a couple of pics to see how it will looke when installed From the Rennspeed website And on the car from autometrics
Matteo, What an awesome car! When do project completion on this?
Jon |
Friends of Warren
I would say that the car with the old 3.6 could be ready by the 3rd week of March... The 3.9 engine will take a little longer... I certainly hope to have it all done by Easter |
We'll have to schedule a "Spring Run" for this monster. Looking forward to seeing it in person.
Jon |
Friends of Warren
I don't know about a 997 cup, but certainly I am in 996 GT3 territory. But the way I see it is that since I am not a pro this has to be first of all FUN. I know I could have bought a faster, more powerful, newer car for less money... But my car will be something special.. something different, almost unique. I will have decided every details of it... It was not meant to go this far.. I just wanted to fix mine after the crash and get it back on the road asap.... When I learnt that it would take a while to fix the tub I thought abt "upgrading" the 3.6... I had some time and some spare cash... And the rest is history... A little better here, a little cooler there, no budget and I ended up with this. Sometimes I wonder if I went a little too far. In the quest of making this the ultimate fun 911 I might have created a "monster" and messed up the "balance". it takes more than a hugely powerful engine and light chassis to make a good car. We'll see... Last edited by 911teo; 02-27-2006 at 07:33 AM.. |
Friends of Warren
Jon
anytime... I'd love to have a spin on yours too... |
The ultimate "as long as I'm in there" 911!!
Porsches: should be on the governments "controlled substances" list!!!
'86 Carrera Cab "The Grey White Whale" '98 Kirkham 427 Cobra(in rehab) '94 Dodge Intrepid ES(very Porsche-like) '99 F-250 SD Diesel(Cowboy Cadillac) |
Sports Purpose 911 Driver
the ultimate 911 is the one you own IMHO. Matteo, your car is unique !
James Shira R Gruppe # 271 1972 911 Coupe 3.8 RS ‘nbr two’ 1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie' 1955 356 Pre A Coupe ‘old red’ 1956 356A Emory speedster build in progress |
[QUOTE]Originally posted by 911teo
[B]First of all I had to replace the whole front suspension. A-arm, struts, cross member etc. so I thought that if I ever wanted to do the ERP kit now was the time... As per the advantages the main benefit is adjustability. Camber, caster, track width can be easily set. Also you get rid of the cross member as the ERP has its own. The arms are longer and the pivo point is raised to improve camber and reduce anti-dive tendencies under braking. Will I take full advantage of this? I doubt it.. at least initially... But it's there and I can only get better. [QUOTE] Cool, I didn't know that. Those are the first pictures that I've seen. You do have to get coil overs in the front though, but you already talked about that with the spring perches and all. Are you doing coil springs in the back? Does the ERP stuff do the same thing in the rear? What the heck does ERP stand for? Thanks for humoring my questions.
ERP is Eisenlohr Racing Products (sp). The fronts are remarkably abjustable, I run it on my car too. You have all the regular adjustments at the top of the strut (even moe if you get plates like Matteo is using) plus you can adjust caster and camber/track width under the car in a matter of minutes or seconds if you are fast!!
The stuff is substantially lighter as well. ( thom and randy's database has the weights) The rear allows you to adjust the toe by lengthening the plate with the big adjuster at the pivot point, very easy. It also adjusts idependant of camber. Once again, this only takes seconds as you don't loosen the rear bolts that mount the spring plate to the trailing arm. I *think* Matteo is using camber boxes for the trailing arm pickups, and this is the ultimate set up as it allows you to adjust camber from inside the car (rear seat area). I don't have the rear pivot boxes (yet) but would sure like them! Matteo will have the ultimate (IMHO) suspension set up depending on what he does for sway bars. It will have a HUGE range of adjustment (think 3 times what a stock set up has), be very compliant, with absolutely no movement due to rubber pieces. The only rubber in this setup is in the tires. Nice choices on the products my friend! I love it! ![]() Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Thanks Jeff
Unsafe at any speed
Incredible project. Will you still be taking it to the track? You haven't left anything to improve if you wreck it again!
87 Carrera Coupe |
What is the piece that parrallels the struts and comes down to the a arm? That isn't in the picture of the suspension.
I'm with Bill
1978 Mini Cooper Pickup 1991 BMW 318i M50 2.8 swap 2005 Mini Cooper S 2014 BMW i3 Giga World - For sale in late March |
Matthew “Sometimes the questions are complicated and the answers are simple.” |
Friends of Warren
