how do you do a compression check on a fuel injected engine
I know you pull the plugs, pull the coil wire, open the throttle to WOT, but what do you do about the fuel?
1986 944 Turbo - Guards Red |
Nevermind Kurt V answered on another of my theads.
For the archives: disconnect ECU from under the seat. It will still crank. OR disconnect the fuel pump (remove the fuse).
Doug
1971 RSR - interpretation |
