Name That Gizmo~!!
Well...actually - name the parts function and location - please.
2 fairly rigid foam cylinders with about a 6mm I.D. thru hole. It's been quite a while since I disassembled the car, and for the life of me I can't remember where these go... I'm thinking on some rod or possibly bowden cable to dampen movement... Anyone know? Thanks in advance! Jim
1980 911SC - 2nd Rebuild in Process - 2005 Porsche Cayenne Turbo - 2013 VW R ________________________ 2000 BMW X5 - 1996 BMW 530i - Toy 4 Runner (x2 or 3) - 1987 Toy Supra - 1988 Honda Si - 1984 El Camino Super Sport - MGA - MGB - Fiat 124 Spyder - Fiat 128 Wagon - 1962 Karmann Ghia - 1951 VW - 1953 Willys Jeepster w/Chevy 286 - 1995 Volvo 960 - 2006 VW GTI |
Will program for food
Front torsion bar assembly, maybe?
Greg Hnat 87 Targa Disassembled 90 944 S2 Auto-x, DE and semi-daily driver 98 Jeep Cherokee |
No...
Dimensions are: 28mm O.D. X 30mm Length X 6mm I.D.
Pretty sure those are not any suspension parts. Went through my entire susp. last winter and did not encounter such part. Not durable enough for suspension. Guessing somewhere in the interior maybe. Did you dissassemble the entire car? Which parts did you go through?
1980 911SC Targa 3.6L |
1.367m later
the pics are a little dark on my monitor but the description sounds like the anti rattle found on items like the climate control cables that are under the front hood as they traverse the blower motor housing. Also found in the mirrors housing but those are generally grey. I've seen on some cars the same anti rattle around the mirror harness plugs under the dash.
Also, if you've been as deep as inside the tunnel the accelerator rod has an anti rattle on it somewhere around the middle.
non velox ad propitiare, verisimile non oblivisci If it's not The Original Automotive Innovations and Restoration, then it's just hot AIR. |
I second Kevin's suggestion that they are anti-rattle devices (or vibration dampers) for the heater control cables. I was working on removing my A/C a couple of months ago and snapped this photo that shows their location:
![]() Cheers,
Brian 1981 930 |
Perfect~!
I had an indistinct memory of something like that - and you've helped a bunch - Thanks Brian~!
Kantry Member
God, I love this board!
Les
Best Les My train of thought has been replaced by a bumper car. |
