911/930 engine serial number
Hello,
I would appreciate it if someone could tell me where the serial number is located on 911/930 engines and how to read the number IE: year, displacement, etc.
Thank you!!
EJ
Old 01-29-2006, 08:11 AM
EJ,
Look the the right of the fan, on the engine case. There are two numbers. The type number will tell you which engine you have (eg. 930/03) and the serial number will identify the year made. You have to have both and a decent book to look up the information. Report back and we'll let you know what you have.
JR
"Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." *** Aristotle
Old 01-29-2006, 08:14 AM
JR,
Thank you for the reply and the offer to help.
I have looked and I can't find the numbers. The engine is in the car and complete. Can the numbers be seen when the engine is in the car?
Please advise and thanks again.
EJ
Old 01-29-2006, 08:38 AM
EJ the numbers are easily visible with the engine in the car. Look to the right of the fan, towards the bottom where it sits in the engine case. There is a vertical surface with one number and a horizontal surface with the other. Both surfaces are part of the engine case. Use a flashlight.
JR
Old 01-29-2006, 08:55 AM
JR,
Wow....I must be a real lamo. I can't find them. I have taken a picture of the area I think I'm supposed to be looking in. Do you have an email address I can send this picture to you at?
Thanks for all your help!
EJ
Old 01-29-2006, 09:22 AM
Seeeu911's Avatar
Look at this thread 911 engine numbers and this site. http://www.elferhelfer.com its in german but very helpfull.
Thanks MARTIN AIDE
"And there's no cure like travel
to help you unravel
the worries of living today.
when the poor brain is cracking
there's nothing like packing
a suitcase ..(or getting in the Porsche) and sailing away " Cole Porter, anything Goes"
Old 01-29-2006, 09:38 AM
Priced-out of Porsches.
mmastro's Avatar
Go to this thread:
Cheers,
Mike
SoCal
Old 01-29-2006, 09:40 AM
Old Member
If you have an AC compressor it might be difficult without knowing where to look.
Look above the oil pressure sender at the base of the fan support for the serial number. Using a flashlight in a darkened garage can help focus your examination to that small area. The numbers are stamped not raised.
Clifton Brown
https://www.mancalamarketing.com
Old 01-29-2006, 12:04 PM
