Recreational User
porschenut's Avatar
how to remove a pin from the connector
Do I need a special tool to get these pins out of the white connector housing? I did this on a motorcycle connector with a paper clip a few years ago but as I recall the connector was a little different than this one. Any way to do it with an ordinary household item?
Old 01-16-2006, 04:54 PM
Dave,
It's better to remove the pin with a pin removal tool. These come in sets and are pretty cheap to buy. If you need to do it before you can get your hands on a tool, look in the end of the connector and see if you can see the tab that must be manipulated by the tool to release ithe pin. You might try grinding a paper clip flat on two sides to make it thin enough to fit in the opening provided. The plastic that the connector housing is made from is a little flexible. If you don't get to rough with it, you can probably get the pin out.
JR
"Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." *** Aristotle
Old 01-16-2006, 05:09 PM
Zeke's Avatar
I find paper clips useless, sorry. They fold up too easily. I use small screwdrivers, even a jewler's SD.
Old 01-16-2006, 05:16 PM
Try this.
http://www.action-electronics.com/molex.htm
Scroll all the way down to AMP/Molex style 4-pin power connectors
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
Old 01-16-2006, 05:22 PM
Or just use a jeweler's flat screw driver as Zeke said and insert it from the back end (wire end) to straighten the locking spring tabs on the pin then push out the pin from the front.
Old 01-16-2006, 05:27 PM
Sorry, insert the screw driver in the front end and push the pin out from front end also.
Old 01-16-2006, 05:29 PM
Early_S_Man's Avatar
Porsche Crest
Dave,
That is a Molex connector ... the factory tool has two parts, a cylindrical sleeve with grip, and a pusher pin with thumb-knob ... and is a fairly expensive tool, when you have to buy it as part of a connector kit.
You can remove a pin with a pair of small 5" needle-nose pliers. The trick is to pull on the wire at the same time as compressing the two tabs that are flared-out -- holding the pin in place in the connector body!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 01-16-2006, 05:32 PM
Recreational User
porschenut's Avatar
Warren, your description of the "two tabs that are flared out" sounds like you're talking about separating the male and female plastic connectors..?
Anyway, I'll see if I can find a little flat blade SD and fiddle with it some more.
Old 01-16-2006, 06:02 PM
Porsche Crest
Dave the Digikey catalog page below has the 0.156" connector kits I was referring to ...
http://dkc3.digikey.com/PDF/T061/0109.pdf
The pic below from the Digikey page shows the two flared tabs I am referring to on both the male pin and female socket:
Warren Hall, Jr.
Old 01-16-2006, 06:17 PM
Recreational User
porschenut's Avatar
You're right Warren, thanks. Actually I managed to get them out a little roughly, but intact, with needle nose pliers and a paper clip. Each pin has a thin metal sleeve that has 3 flared tabs near the crimp end. The pic you posted appears to be correct except for the number of tabs, unless I'm looking at the wrong thing.
The pin removal tool in the link that bazar01 posted is exactly what I needed. next time!
Anyway, thanks to all for the guidance.
Old 01-16-2006, 07:35 PM
You need a pin removal tool for this. Check with one of the national "jobber" parts stores like NAPA- i believe they have an inexpensive tool that looks like a 4 way lug wrench with different pin tools on each side.
Mackskibum aka Dave Austin
'66 911 Work In Progress (#303734)
'85 911 Carrera
06 325XI
'05 Envoy XL SLT
Old 01-17-2006, 05:31 AM
