JR_NYC's Avatar
SC Wouldn't Start
Maybe someone out there can help me out.
So after driving my car for about 45 minutes this morning I stopped at a Dunkin Donuts. I came out after about 15 minutes and tried starting my car but had a very hard time getting it started. It would turn over without hesitation, idle roughly at about 400 rpm for 1-2 seconds and then die. The engine temp was just below the 1st line/operating temp. I tried starting it about 10 times, waiting a few minutes between attempts. Finally, on my last attempt it idled for about 5 seconds and then I gave it gas and held it at 2000 rpm or so for about a minute. When I took off the gas, the car went back to its "normal" idle which is about 700. I was then able to drive the car all the way home without incident, praying it wouldn't die while in line at the toll booth.
Other relevant information:
- Until about a month ago, the car started effortlessly and when cold would idle at about 1200+ until it warmed up. Once warm, the car idled smoothly (not lumpy) at about 900.
- One day, I stopped to get gas. When I restarted the car after filling up the car began idling at about 500 and was lumpy. There was something noticably different, like something suddenly went out. I turned up the idle screw to raise the idle to ~700.
- Ever since that time, the car has idled low and lumpy (not hunting though, just a bit rough) and when it's cold it idles at about 700-800 max. But even so, it has never died when cold.
- Otherwise the car runs perfectly.
Any ideas?
I guess I'd better order that Bentley manual. And a AAA membership.
'82 SC pewter metallic
Time and Relative Dimension(s) in Space
Old 01-22-2006, 12:32 PM
JR_NYC's Avatar
So far the CIS threads I've read talk about the fuel accumulator and the warm up regulator as being common problems. Anyone?
Old 01-22-2006, 01:46 PM
David's Avatar
Start the diagnosis by buying some CIS fuel pressure gauges and checking the cold and hot pressures. It sound's like a WUR problem but I wouldn't buy any parts until you do the checks. Do you have the Bentley or a Porshce manual? They have all the CIS checks in them.
Old 01-22-2006, 01:50 PM
Scott R's Avatar
Second the fuel pressure test, sounds like it's leaking back after you turn it off.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 01-22-2006, 02:55 PM
feelyx's Avatar
Make sure the seal around the "blow off vavle" is sealing.
Tim in Sac
Old 01-22-2006, 02:56 PM
