Using a direct drive polisher to polish paint . . . any tips?
As I've found, a random orbital with the proper nonaggressive pads and polishes is pretty mild and risk-free.
But looking to go to the next level! Colorsanding and polishing it out. Tried it on a trunklid, laid down some paint, 2000 grit wet sand, but the random orbital doesn't cut it to polish it out. Not compatible with the heavy cut cleaners, which seem to require 1000 or so rpm of direct drive polishing. Even the 2000 wet sand paper leaves cuts too deep for a random orbital. So I'm going to try a direct drive with Meguire's cutting polishes and pads. Any tips? Other than start slow and be careful?
Get the correct pad for each cutting polish and don 't mix the pads.
Here's my before and after shot of my BMW roof spray with a rattle can spray and polish / buff. Before After
Air Medal or two
really not too much to it.....mostly do not concentrate in one spot too long...esp with a "rubbing / polishing compound. Better to do too little then too much as you can always go back over it
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between |
Watch those edges!!
1983 SC 1958 TR3 2014 Cayenne GTS (wife' car) 2006 KTM 450EXC |
Like everyone else has said, start with a light compund, let the pollisher do the work and don't burn th epain by overdoing one spot too loong. Kinf of like a "wax on /wax off" motion but with a polisher -
Can't ever say that phrase and not remember the man. RIP Mr. Miagi
85 911 SuperSport No more looking! The jewel is mine! 89 Jeep Wrangler A jewel in the rough 2000 Grand Cherokee Family Wagon with Jewels on board |
I need to do this too. Any recomendations on specific polishers, pads,
compounds and where to get them??? Thanks, Mike
1985 Carrera 1995 325is 2000 Grand Cherokee |
I can't remember if I have the 847 or the 849. I can check when I get home. But here is a link to a good polisher. Use it on the LOWEST setting:
http://www.dewalt.com/us/products/tool_detail.asp?productID=173 Then buy the "Hook and Loop" or "hookit" type backing pad. Then the 3M rubbing and polishing pads for it. Then get the 3M imperial Hand Glaze. Lastly, put on your wax for protection. This is just what I use.....
Bill 997.2 |
