Modifying rear bumpers
Has anyone had much success modifying their rear bumpers so they contour after adding SC flares? This would be for the early stlye bumpers-71'. I was looking at it last night and could decide if it was worth it.
Old 02-05-2006, 04:57 AM
Zeke's Avatar
If you had the end pieces that go with the RS steel bumper, you could "flare" your steelies to match. You would need some serious metal working tools.
Old 02-05-2006, 08:24 AM
stormmaster's Avatar
Send a message via AIM to stormmaster Send a message via Yahoo to stormmaster
I just wish there was a source for longer rubber strips for mid year cars that would allow removal of the big bumper blocks and just run the rubber strip in their place....not to hijack the tread....
Don Booth
87 Carrera Coupe (Current)
70 911 T Coupe
74 914
Old 02-05-2006, 09:07 AM
What about using an extra rubber strip from the front bumer? Might not be a perfect match, but it would get you close.
89 Carrera 3.4
"There is a right way to go around a corner - it's called the line." -- PCA DE speaker
bryteside.com - good things happen.
Old 02-05-2006, 09:12 AM
I dont want it to look cobbled up....although I did just have a thought...I will let you know if I figure out something....
Don Booth
70 911 T Coupe
74 914
Old 02-05-2006, 09:15 AM
buster73's Avatar
The stock metal rear bumper of my 73 was modified to match with the RS flares. You first cut off the outer end of the bumper. Then you align the cut piece with the fender and weld a metal filler strip in the gap between the two segments (ca. 3/4" wide). A good body shop should be able to make it fit.
Regards,
Guenter
73.5 911T, mod
Old 02-05-2006, 10:53 AM
PorscheGuy79's Avatar
I <3 orange 911s
Matthew
“Sometimes the questions are complicated and the answers are simple.”
Old 02-05-2006, 11:26 AM
Zeke's Avatar
Very nice, Guenter.
Old 02-05-2006, 11:37 AM
That looks sweet!!!!!!!!!!
Old 02-05-2006, 11:59 AM
Check this out
73 RS Bumper ends extensions?
'56, '59 356A Coupes
'67, '68 912 Coupes all gone
'72 911T coupe
Old 02-05-2006, 05:13 PM
That looks like a different style bumper. The extention would seem to be more difficult using an early bumper.
Old 02-05-2006, 06:58 PM
