Longhoods Unite!
PhatRedHead's Avatar
Send a message via AIM to PhatRedHead Send a message via Yahoo to PhatRedHead
MSD Dumbness
the car: 1970T
Engine: 2.2L
Dizzy: Marelli
Coil: MSD Blaster
Old CDI: Bosch
Questions:
1) The old 3 pin connector into the bottom of the bosch box, is the red in the middle of the connector switched power or constant power?
2) if that red wire is switched power, where should i pick up constant power with the "heavy red" wire?
3) do i use the white wire to pick up the spade near the cap on the dizzy??
i have searched thru most of the archives, but i can't find answers to these specific questions.
Thanks,
Joe
1970 911T -- Neglected, oil burning problem, batman smoke
1974 914 2.0 Weber'd -- new project!!
**My Wife and I bought our first house in August of 2009, the footprint of the house is just over 1100 sq. ft...my garage is just over 1000 sq. ft. We compromise well **
Old 02-07-2006, 06:20 AM
Yellowbird RS's Avatar
you need to run a wire to the batery or try one of the fuses in the engine bay
check this thread: MSD wiring help needed
X/A
Old 02-07-2006, 07:55 AM
Longhoods Unite!
...thanks, but didn't really answer my question
Old 02-07-2006, 08:52 AM
1- CDI red wire is switch power.
2-There is a power lug at rear of electronics shelf where constant 12 v power is availablke. I'd put the MSD connection here. Much easier than running to starter.
3-white wire goes to dizzy lug which goes to points.
You will probably need the tach adapter to get yopur tach working. Good luck.
69 911 2.3Ez
85 928S
Old 02-07-2006, 09:10 AM
Longhoods Unite!
had the tach rebuilt to be compatible with the MSD unit THANKS VERY MUCH!!!
Joe
Old 02-07-2006, 09:32 AM
MSD sells a tach adaptor. The power wire should come from the battery not a fuse panel and the MSD unit needs to be grounded.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 02-07-2006, 10:03 AM
Longhoods Unite!
Joe
Old 02-07-2006, 11:04 AM
FrayAdjacent911's Avatar
Send a message via AIM to FrayAdjacent911
Remember, the MSD has two positives: One as a 'on/off switch' and one as the power it actually uses. The latter is best to connect to the positive lead on the starter motor. The other one needs to be connected to something that goes hot when the ignition is turned on.
Matt J.
69 911T Targa - "Stinky"
2001 Boxster "Stahlgewehr"
Old 02-07-2006, 11:17 AM
Longhoods Unite!
with the old original wiring harness, there was a braided ground that went to the base of the dizzy, and with the MSD, there is just one big ground wire that i bolted to the chasis, do i need to be worrying about re-grounding the dizzy???
Old 02-08-2006, 05:27 AM
Longhoods Unite!
car starts and runs, but still rough due to dizzy being off and carbs needing tuned, but still no tach worky, black and purple wire straight into msd box on the tach spade. tach was rebuilt with new guts which include internal tach adapter, my only guess is a short in the line to the tach, but i had continuity...so i'm confused...
Old 02-08-2006, 05:02 PM
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 02-08-2006, 09:52 PM
