What would generally cause the idle to be low and rough most of the time but then pur around 950 randomly when warm? Most of the time my idle sits at around 550 but occasionally goes to 950 or so when warm then back to rough and 550 again. Any ideas?
I have had the alternator rebuilt, valves adjusted, plugs replaced, dist cap and rotor replaced, plugs wires will be replaced when they arrive. I also cleaned the ICV as per the post located here. Could this still be an alternator (voltage reg) problem? The voltage across the battery is a steady 13.7 volts. This rough idle is driving me crazy .. sometimes when I come to a stop the idle dips like its gonna stall then pulls back up to 550 and rough. I only use premium 92 octane fuel. I am also going to have the fuel filter replaced and the air filter too even though it looks fine. I am running out of things to replace. Any help would be greatly appreciated :-) Last edited by ThePointman; 02-08-2006 at 09:02 PM.. |
Somewhere in the Midwest
Could be the idle air control valve. Run a search..it's been dicussed lots of times.
This is a long shot but I had somewhat similar idle issues once. My issue turned out to be the connector that goes into the air meter. When I plugged the connector in, two of the contacts were pushed out. Everything looked fine but when the connector was off, you could see two contacts not in line with the others. This caused a really bad a/f mixture.
Don 24 Cayman GTS - GT Silver 23 Cayman GTS - Arctic Grey - Sold 97 993 Coupe - Arctic/Black - Sold 13 991 Coupe - Platinum/Black - Sold, 87 911 Coupe - Venetian Blue |
Banned
You are not alone, sounds like the Air Control Unit.
My 85 has an aftermarket unit, I'm switching back to stock and adding a chip. I have the exact same operating issues. It sounds like a Air/Fuel mixture as Don mentioned. This causes the running issues, you need to get that dialed in. Good Luck - 3.2 Carreras are wonderful cars. Thank you, Jason Last edited by Jason Cullen; 02-08-2006 at 09:31 PM.. |
When was the last time you checked your mixture? You might be running rich.
1984 Targa |
Friend of Warren
Kurt V No more Porsches, but a revolving number of motorcycles. |
Somewhere back in my feeble brain I seem to recall this could be tied to the O2 sensor. You might try disconnecting it but don't leave it that way...I think Motronic 3.2's are not supposed to be run long without it connected.
Buck '88 Coupe, '87 Cab, '88 535i sold, '19 GLC 300 DD Warren Hall, gone but not forgotten |
1984 Targa |
Immature Member
Hey Marc, buddy! (Pointman)
A common culprit for wonky idle is a vacuum leak... trying to find it (if it exists) is another problem. My 84 3.2 has similar issues, except the idle dips to stall level after lifting the throttle until it is full warm. Then it seems to settle around 800 rpm. I am going to clean the ICV this spring. As per your problem... I noticed with mine that when I take off the oil filler cap the idle surges and sounds a bit rough. When i cover the filler neck with the palm of my hand it smooths out again. Try this just to see if it's something as simple as a bad seal on your filler cap. That's about the easiest vac leak to repair. Otherwise it may be time to get vacuum checked out and see if there is a leak somewhere?
1984 Carrera Coupe = love affair 1997 Eagle Talon Tsi = old girlfriend (RIP) 2014 Chrysler 300 AWD Hemi = family car "Lowering the bar with every post!" |
UFLYICU
Airflow Meter probably has worn grooves on the potentiometer that provides the airflow reference voltage to the DME.
_______________________ Racer Rix Spec911 #5 prc-racing.com |
How old is your o2 sensor? I replaced mine and it cured the idle hunting problem.
If it flows, it goes. If its smooth, it moves. Any questions? 96 993 C2 (Current) 87 911 Factory Turbo-Look Cab (Sold) 85 911 Factory Turbo-Look Targa (Gone) |
