Senior Member
My coils are mounted like Ingo's. Would not want them on the engine due to vibration IMHO.
JoeA
Old 03-01-2006, 04:04 PM
Originally posted by ischmitz
I used a stock relay socket from a 964. It was not the DME relay but for something else. I opened the plastic base and soldered new leads to it. The capacitor should have been in the donor car. It sits behind the metal plate in the black box in the engine compartment.
On the capacitor, I'll have to look, but if it was there, I got it!
I pulled a few extra relay sockets from the car, but the terminal numbers didn't match what you have in your diagram (#1,2,3...)
The relay itself has a little diagram on it with the terminal designations (30,87a ....) I assume I should not worry about what's on the connector, but follow the designations. Right?
Thanks again for all your help!
Things are comming along.
Bill Miller
81 Targa Guards Red
3.6, M&K 1 out, S4 brakes
83 ROW CAB Rubinrot Metallic (RIP)
Old 03-01-2006, 06:00 PM
How does one mount the coils like Ingo has them mounted? I have the fuel accumulator and fuel filter in the way on my SC? Can this be moved?
1981 911sc RoW Coupe (forever under 3.6L conversion)
2003 996TT Basalt black
Old 12-21-2009, 09:55 PM
jm58's Avatar
Here is my 3.6 coil place:
[img=http://img264.imagevenue.com/loc175/th_82915_DSC06503_122_175lo.JPG]
Old 12-22-2009, 03:59 AM
DW SD's Avatar
Note the rubber isolators between coils and the body and the fuel filter and the body.
1971 RSR - interpretation
Old 12-22-2009, 07:05 AM
Senior Member
DW,
Very nice looking and like your idea on the photo!
Old 12-22-2009, 07:52 AM
Is eliminating the fuel accumulator ok to do for a 964 motor?
My 911's factory rear fuse box and filter setup looks like the one pictured on timmin's website.
I have the 964's fuse box and want to use it, but the coils won't fit with the fuel filter and accumulator in their stock location. The wiring harness isn't long enough to mount the coils with the motor like 993 and I prefer to mount them on the fender wall. Ideas?
Old 12-22-2009, 07:58 AM
DW SD's Avatar
Originally Posted by Joeaksa View Post
DW,
thanks!
It helped me keep the wires in the harness connector straight.
It is indeed interesting when these threads are resurrected years later. The photos on my computer are nearly as old as the thread. Haven't seen them in moons.
Doug
Old 12-22-2009, 08:57 AM
midnight911's Avatar
mine looks similar to jevvy's pic.
1984 911 Carrera Coupe - 32C #73 - M64/05
1998 E36 M3 4dr
2006 Sienna 5dr - the hauler
2004 Lexus GX470
2010 Cannondale Caffeine II - Lefty
Old 12-22-2009, 09:54 AM
