Gordo2's Avatar
Question Curiousity Q: Oil path/flow in an engine
I've been looking at Wayne's engine rebuild book and realized that though I consider myself knowledgeable on how an internal combustion engine works, I have no clue how the oil moves throughout a motor.
Can someone describe the flow path for me from the point the oil goes through the pump? Specifically:
-How does the oil get to the journals on the crankshaft?
-How does it get on the cylindar walls?
-How does it get to the camshaft, rockers and valve stems?
I realize there are oil holes/squirters in the engine but are there oil passages built into the case that recieve pressurized oil from the pump?
A graphic would be awesome. Any engine type exemplifying oil flow would suffice. I assume the principles are similar enough (i.e. nothing unique about a 911 engine oil flow outside of the dry sump system).
Thanks, Gordo
Don "Gordo" Gordon
'83 911SC Targa
Old 02-25-2006, 07:01 PM
This is a nice diagram. Unfortunately I didn't record the source when I downloaded it.
Perhaps someone will recognize this and credit the source.
DOUG
'76 911S 2.7, webers, solex cams, JE pistons, '74 exhaust, 23 & 28 torsion bars, 930 calipers & rotors, Hoosiers on 8's & 9's.
'85 911 Carrera, stock, just painted, Orient Red
Old 02-25-2006, 07:29 PM
Gordo2's Avatar
Perfect!
Thanks 2.7 Racer, exactly what I was looking for. First time I have seen that diagram.
Further questions:
-Are the lines that run to the crankshaft and up to the cam towers oil passages built into the block?
-How does the oil get to the cylindars and piston pins?
Thanks, Gordo
Don "Gordo" Gordon
'83 911SC Targa
Old 02-25-2006, 08:03 PM
The above figure is just a schematic; oil is pumped down drilled passageways in the center of the crankshaft and through a spray bar in the cam towers.
Old 02-25-2006, 08:47 PM
len911's Avatar
The source of that picture is from a PCA Panorama magazine from a few years ago... Lou
'76 911 "Moneypenny" daily driver
'74 911 "JLo" IROC DE Car
'03 CRV, '02 Jeep Grand Cherokee
'03 Holiday Rambler Admiral SE, 30ft, 8.1l, 340HP, 455Ft#
http://www.nicotra4.hpshare.net/BasketCaseMotorsports/
Old 02-26-2006, 11:11 AM
Grady Clay's Avatar
I added the piston squirters (red dots) and the internal
crankshaft drilling (green lines). The rod journals are
fed from the #1 and #8 main bearings.
Best,
Grady
Old 02-26-2006, 11:52 AM
