Whats the trick removing rear caliper
Whats the trick for removing the rear calipers on an SC. What do you use to get on the caliper bolts. Theres not much room to work. I'm thinking about grinding down a socket to give me more room.
Any suggestions? Jeff
Jeff C 76 912E 2.6L |
19mm box end, come in from the bottom
Jason 81 SC 97 328is 87 Jeep Comanche (RIP) |
Formerly bb80sc
Ditto, IIRC, an offset wrench makes it even easier.... Also, do yourself a favor and get some mechanics gloves, nothing like slicing your hand on the dust shield when your hand slips
Cheers -Brad 2015 Cayman GTS 2015 4Runner Limited |
Six-point 19 mm or 3/4" socket on a medium flex-handle [breaker bar] ... or a combination wrench with a permanently mounted flex socket on one end.
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
That's timing.
I just reinstalled my rear calipers after my brake upgrade. The bottom caliper bolt is a pain. I just used a small ratchet and short 19mm socket. The hard brake line was more of a challenge to tighten up after the caliper was mounted.
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
