Jcon's Avatar
Whats the trick removing rear caliper
Whats the trick for removing the rear calipers on an SC. What do you use to get on the caliper bolts. Theres not much room to work. I'm thinking about grinding down a socket to give me more room.
Any suggestions?
Jeff
Jeff C
76 912E 2.6L
Old 02-26-2006, 07:23 AM
19mm box end, come in from the bottom
Jason
81 SC
97 328is
87 Jeep Comanche (RIP)
Old 02-26-2006, 07:31 AM
Formerly bb80sc
Vipergrün's Avatar
Ditto, IIRC, an offset wrench makes it even easier....
Also, do yourself a favor and get some mechanics gloves, nothing like slicing your hand on the dust shield when your hand slips
Cheers
-Brad
2015 Cayman GTS
2015 4Runner Limited
Old 02-26-2006, 08:22 AM
Early_S_Man's Avatar
Porsche Crest
Six-point 19 mm or 3/4" socket on a medium flex-handle [breaker bar] ... or a combination wrench with a permanently mounted flex socket on one end.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 02-26-2006, 08:29 AM
Oh Haha's Avatar
That's timing.
I just reinstalled my rear calipers after my brake upgrade. The bottom caliper bolt is a pain. I just used a small ratchet and short 19mm socket.
The hard brake line was more of a challenge to tighten up after the caliper was mounted.
Pacific Blue
Wayne
Old 02-26-2006, 08:59 AM
