engine code 930/03
Engine code 930/03. What displacement and year production is this engine?
Are you sure that's 930/03 ?
RGruppe #180 So many cars.. so little time!! |
Fleabit peanut monkey
The 76/77 3.0 Carreras were 930-02 and if sporto trans 930-12
1981 911SC Targa Last edited by Bob Kontak; 02-06-2014 at 08:24 AM.. |
Yes, and the 930/04 is 78/79 3.0 SC
My 79SC 3.0 liter ROW is a 930/03
Terry
79 SC Minerva Blue ROW Non Sunroof Crank Window Coupe 3.0 SSIs, Backdated Heat COA: Passenger Side Mirror, Manual Antenna & Dunlop Tires |
This engine is in a 1978 Euro version 911. The date of production sticker in the door jamb shows 5/78 as the production date.
The engine has a green shroud which I've only seen on 2.7 engines. The date stamped in the engine case appears to be 930/03 but I'll check again. |
ding,ding, ding.. you got it!
I just checked the number on one recently sold.. duh, that's what it is!
Is this at all special or meaningful versus 930/04 or only maybe to someone with a '79 ROW SC?
May have answered my own question. Looks like 29 more horsepower in '79 compared to the US version
To the OP... The green shroud is wrong. Start looking to see if other parts are wrong, too. Start withe intake and CIS parts. JR |
Simon's Porsche 911 SC Site |
I have two 930/03's....
European SC ('78) Nice engine....and one of them came with a green shroud standard. Dennis |
The 30 Nm more torque is interesting.
Is it the lack of emissions equipment or a different camshaft? I guess both to get that big of a difference at the same RPM??
Derrick |
^^^ Thanks.
I do remember seeing the different distributor curves in the shop manual now that you pointed it out. It's funny how less timing will make a car pass emissions. I used to have to retard the heck out the timing in my Mustang to get it to pass with the cam that was in it. Ahh the 80's.
Derrick Last edited by 1979-930; 05-25-2017 at 09:57 AM.. |
The only thing I physically found in the early euro 3.0 was the .25 base gasket vs the .5 base gasket.
I never found the cylinders to be different like the Carrera euro and US which have the same casting numbers but different piston heights. Bruce |
