Engine Drop Question
I've got a 3.2L and I was curious if I should remove the heat exchangers prior to the drop? Is it OK to support the weight of the engine on the heat exchangers...utilizing a piece of plywood on a furniture dolley?
What is the best way to remove the heat exhangers while the engine is in? I couldn't use my socket wrench/hex bit/extension because the base of the socket was too wide. It looks like you need a very long hex bit...what's the best tool for future reference?
86' 911 Carerra
Old 05-03-2006, 07:53 AM
LakeCleElum's Avatar
Leave them on.....They will support the weight of the engine very nicely. To remove the HE's, spray with PB Blaster, let sit a few days and repeat several times. Then use heat (torch) and be careful to not break any studs....
Bob S.
73.5 911T
1960 Mercedes 190SL
Old 05-03-2006, 08:17 AM
ausgezeichnet's Avatar
I agree don't remove them. they can support the weight and make a nice platform if you use a ATV type of jack to support the motor
Mike
'84 911 Carrera Coupe (totaled)
'83 911 SC Coupe
‘06 Aston Martin Vantage V8
Old 05-03-2006, 08:41 AM
MBruns for President
JeremyD's Avatar
they are sturdy - and more importantly - nice and flat - keep em on...
Old 05-03-2006, 09:40 AM
Hendog's Avatar
Does that apply to SSI's?
Henri
'87 Carrera coupe: Venetian blue
Old 05-03-2006, 09:43 AM
randywebb's Avatar
yes
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 05-03-2006, 10:42 AM
