Engine Drop Question
I've got a 3.2L and I was curious if I should remove the heat exchangers prior to the drop? Is it OK to support the weight of the engine on the heat exchangers...utilizing a piece of plywood on a furniture dolley?
What is the best way to remove the heat exhangers while the engine is in? I couldn't use my socket wrench/hex bit/extension because the base of the socket was too wide. It looks like you need a very long hex bit...what's the best tool for future reference?
86' 911 Carerra |
Leave them on.....They will support the weight of the engine very nicely. To remove the HE's, spray with PB Blaster, let sit a few days and repeat several times. Then use heat (torch) and be careful to not break any studs....
Bob S. 73.5 911T 1969 911T Coo' pay (one owner) 1960 Mercedes 190SL 1962 XKE Roadster (sold) - 13 motorcycles |
I agree don't remove them. they can support the weight and make a nice platform if you use a ATV type of jack to support the motor
Mike '84 911 Carrera Coupe (totaled) '83 911 SC Coupe ‘06 Aston Martin Vantage V8 |
MBruns for President
they are sturdy - and more importantly - nice and flat - keep em on...
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Does that apply to SSI's?
Henri '87 Carrera coupe: Venetian blue |
yes
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
Thread Tools | |
Rate This Thread | |
