I have tried some degraeser on some unseen clad plated parts and they seem to loose that plating, do I need to use some other form of cleaner or just dilute the degreaser some?
85 911 SuperSport No more looking! The jewel is mine! 89 Jeep Wrangler A jewel in the rough 2000 Grand Cherokee Family Wagon with Jewels on board |
Yes you are right the inorganics and strong organics will take the coating off.
I have found that simple green slightly water diluted will work fine, but do not soak it in it. hope this helps antares |
Diluted simple green huh? Thank's for the tip, I'll try that.
Anything more than a mild cleanser will take the plating off. Many have removed quite a bit of the hardware when detailing the engine bay area and had the whole lot replated. Not too expensive and brightens the whole assembley up quite a bit.
Warren & Ron, may you rest in Peace. |
I'm not doing any overhauls right now, it's just for those while I'm in there moments and I try to clean everything up when putting it back together.
