http://forums.pelicanparts.com/uploa...1146053884.jpg |
New verses old-part 2.
http://forums.pelicanparts.com/uploa...1146054171.jpg |
Anyone can post the model of Bosch copper cores?
Thanks. |
kach:
NGK also makes Iridium plugs with the same heat range as the ones you show; they make make a good alternative to the standard "ES" type. jp |
I went to Autozone today after making a call. They have many Bosch which has the copper core, and many NGK starting with BPxxx. I lean over the Bosch since this is a German car. NGK would be my first choice if it's a Japanese car, but there are many Bosch plugs with copper core there. The one their computer recommended is BPRxxx and I forgot the model you guys recommended so I had to run home, got on the imternet to find BP7ES and they do have it for only $1.95 each. Good deal and only a mile away.
Now question on gap. What I found after searching here is between 0.024"(0.6mm) and 0.032"(0.8mm) is ok. Is this true? Any exception? Thanks all. |
| All times are GMT -8. The time now is 09:57 AM. |
