Rear cusion delete sub boxes, how to
First you make the baffle board and tape off your interior (after pulling rear cusions)
next get your f/g mat ready the next step is to slide in the baffle board After f/g sets, pull out boxes and trim off excess f/g. Pulling boxes will pull out some of your tape, retape were nec.
Euro 83 cab. SC |
Next you put the boxes back in and fill with duroglass (fiberglass filler/putty) use enough so you will have excess to grind off
Pull boxes again and grind/sand off excess duro, check fit Next mix bondo and resin together (thick soup consistency) and pour in boxes. swoosh around to make sure you get good coverage. This helps with any pinhole leaks you might have. It also makes the box less bongy (a problem with f/g boxes
Euro 83 cab. SC Last edited by piedogger; 03-07-2006 at 02:33 AM.. |
Last you cover with nice German OEM carpet
Thats it! run your speaker wire into boxes and bolt down,mount the speakers and your done. This is a customers car, waiting on the oem match carpet but you get the idea. The carpeted ones are in the clasifieds as we speak!
Euro 83 cab. SC |
Reminds me of the subwoofer where Howard Stearn would have his lovely guest seated while purring into the mike.
Cheers, Joe |
These are now for sale, check classifieds.
f/s 911 subwoofer boxes
Euro 83 cab. SC Last edited by piedogger; 03-11-2006 at 07:50 AM.. |
nice!
X/A |
Make Bruins Great Again
Re: Rear cusion delete sub boxes, how to
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
LOL! Yes they do. When carpeted they pretty much disappear.
Euro 83 cab. SC |
Interesting but isn't the freq response of the sub cabinet based upon the internal volume of the enclosure. So what you have is a sealed enclosure with very little internal volume.
Peace, Ron www.ronorlando.net 78SC Targa 3.2 SS, 964 cams, CIS, SSI's,Dansk Own a gun and you can rob a bank , own a bank and you can rob the world. |
Most 8'' woofers are designed to work in .35 cubic ft. This box is right there, too big of box and you loose output, too small and you loose bottom end. The days of large sub boxes for the most part is over.
Euro 83 cab. SC |
Customer finally came back to have these finished. I still have a pair of these in Black available.
Euro 83 cab. SC |
Nice results. Looked to me like emergency porta potties first.
Good thing they are speakers. No put on the Mozart CD.
81 SC, www.frankschroeter.com |
coolcavaracing.com
How do they attach??
Pål (Paul) - The Norwegian lost in Finland... 1978 911SC 3.6 | 2001 Boxster S Racing Car | 1966 912 based 911 RSR replica racing car (for sale!) come and follow the Porsche Sports Cup racing fun and me at www.facebook.com/coolcavaracing
One screw thru the bottom
Euro 83 cab. SC |
coolcavaracing.com
So you have to remove the seats and belts to fit it all in place then?
yes. They would probably stay put w/o the screw making them easily removable.
Euro 83 cab. SC |
the set of rear cushin delete boxes have gone to ebay
Here is another type of box I did recently in a targa, ![]()
Euro 83 cab. SC |
