syncroid's Avatar
Making progress on my 3.4 twin plug conversion
Well I am getting pretty close. I got my sheet metal back from the powder coaters today. Its going to be hard to wait for that splitter.
Dan
2002 996 C4 Cab w/ Jake Raby 4.0
2024 Tacoma TRD Offroad 4x4
2003 Range Rover HSE
Old 03-10-2006, 05:54 PM
WydRyd's Avatar
WOW, awesome
Why don't you just hook up two MSD 6A's and a pair of Blaster coils?
No need for the Andial Splitter.
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 03-10-2006, 06:30 PM
If you are running the Motronic, we just released a wasted spark setup (no distributor needed) that works with the Motronic system. Plug-and-play setup, no additional hardware except the electronic we provide.. It supports single and twin plugs setup..
John
Old 03-10-2006, 06:45 PM
WydRyd's Avatar
How much is this, Fast951?
Merv
'89 911 Turbo Cab
Old 03-10-2006, 07:11 PM
Doesn't want/need a 3.6L
Carrera3.5L's Avatar
Stick with the Andial Splitter and the additional Bosch coil. The final product will be an OEM quality look & install.
Your motor (other than the distributor which to many smog techs looks original anyway) looks bone stock, that much easier to pass the visual test when going through a CA smog check.
BTDT.
Just consider losing the heat exchangers/catalyst for the other 23 1/2 months, as these will restrict power. Depending on what other mods you have done, a 3.4L twin-plug with stock heat exchangers/catalyst will make 250-260 horsepower on an engine dyno. We built these all the time at Andial using 964 cams, modified intake plenums & a Tezet sport muffler.
Looking good, hope its running soon.
Ralph
1988 Carrera w/ 3.5L Twin-Plug
2008 Cayman S (coming soon)
Old 03-10-2006, 08:59 PM
syncroid's Avatar
BTDT.
Ralph
Yes I will wait for the Andial splitter to become available. I looked into the MSD setup and did not like the whole "non factory" look. I like the under stated sleeper look. I'm not against the MSD setup one bit. Its just not for me!
Every car I have ever put together has had that "wait a sec...is that stock, or is it not look". That is the effect I am after. I'll be driving this car daily when its done. I want it to be as legit as possible with the California smog laws. I think the referees would even agree on this one. It should run cleaner out the tail pipe now then when originally equipt.
I need to fabricate a stainless heat sheild between the cat and the lower 1-3 plug wires still. Ideas welcome.
Fast951 I am interested in hearing more about your set up on the wasted spark set up. Tell us more!
Dan
Old 03-10-2006, 09:39 PM
