Slippery Slope Victim
NY65912's Avatar
How does a 915 trans hold up to 400hp?
With the thought of diving into the pool of boost head first the question now becomes............
Can a 915 trans hold up to a 400 hp 3.2???
MikeČ
1985 M491
Old 03-09-2006, 06:08 PM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
A lot depends on whether you plan to drag-race, or run WOT for long periods of time on the track at 120 degrees ambient temps. For every usage pattern there are different challenges to tackle for longlivety.
Make sure it gets properly prepped (intermediate plate insert, solid bearing retainer, OIL COOLER, re-enforced side cover, etc) I would talk to Wevo and see what they have in store for you.
Good luck,
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 03-09-2006, 06:20 PM
Grady Clay's Avatar
Better than a 901/911.
Not as well as a 930.
There is a reason Porsche used that big 930 transmission with the Turbos.
Of course there are the G50 and G64 variants.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 03-09-2006, 06:45 PM
Insert Tag Line HERE.....
rattlsnak's Avatar
You will hear all sorts of different opinions on this one. I had a bone stock 915 from a 78 SC behind a C2T engine, (@400HP) for 3 years with hard track use with no problems at all. Now, is it the best solution, of course not, but it worked for me. I did no drag racing, or slamming of gears, or even AX. Your results may vary!
That being said, if you do the above upgrades, you should be fine.
Marc
Old 03-09-2006, 07:09 PM
WydRyd's Avatar
Protomotive have the 915 listed for power levels up to their Stage 2 kits (or ~485HP). A 915 will certainly hold up to 400HP. Again, depends how you treat it, just like any other gearbox though. Be preventative and do the above upgrades and treat her nice. She'll love you right back
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 03-09-2006, 07:31 PM
jluetjen's Avatar
The limiting factor with the Porsche transmissions is not the HP, but the torque.
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 03-10-2006, 04:27 AM
charlesbahn's Avatar
Needs to be a later model 915 to hold up to 400 HP, according to Protomotive. Not sure exactly where the cut off is.
From a previous thread:
Was curious about ajackson's question about the 300 HP limit for a 915 tranny, so I asked Protomotive what their experience is -
"Depending on the year, they may be right.
The early 2.7 trannies can get bashed by a good 3.2 na engine.
The 1978-up 915's have a aluminum casing and a reinforced mainshaft and we commonly run mid 500's through them.
A strong Stage 3 with about 600hp will trash them though.
But it's not so much power that is killing them, but torque.
Many people are putting them in 930's and killing them with only 400hp, but at the 1.2 bar required from a 930 to get 400hp they're making nearly 500lbft of torque.
With a Carrera based system, at about 1.2 bar, we're making about 600hp due to the rpm capabilities.
So, with our turbosystem, with the high power, lower torque, we're able to run much more power through the 915's without hurting them."
"Igneous Aquam et Laudi semper"
Carl Muckley
Old 03-10-2006, 04:30 AM
Irrationally exuberant
ChrisBennet's Avatar
I'll add Heat as a factor too. The interference fit of the bearings in a 915 is not that tight. Get that case hot (like racing) and the race will be loose in the case.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 03-10-2006, 05:08 AM
All the posts here a true ( torque is the issue more than HP, ...yes it's OK, but Porsche went to larger units for a reason...etc).
Historical factoid is that the 915 evolved as a street version of the 916 box used behind 908's....and they made something like 350 hp and lived for 24 hours at least with a madman behind the wheel !!
- Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 03-10-2006, 05:30 AM
Interesting info, Wil.
Also,
Chris's info just adds more support to the addition of a trans cooler.
Are the Euro coolers the only ones on the market or is there a $$$ friendly DIY solution?
Warren & Ron, may you rest in Peace.
Old 03-10-2006, 05:59 AM
The Euro 915's ( at least those w/o cat...there was a choice)..had the gear-driven oil pump / coolers for the transaxle...but they also included an internal spray bar or distribution system, for the return-oil.
We can fab something up as a DIY effort, but it would likely be electric motor driven and would lose the benefit of a spray bar unless you want to do ( or are in the middle of ) a transaxle rebuild.
Look at what Thom Fitzpatrick ( widebody911) did. If I find the link I'll edit and post it here.
- Wil
Wil Ferch
Old 03-10-2006, 08:32 AM
I also asked Todd at Protomotive about this, in fact I had a cooler to DIY install. He said if I wasn't going to race the car not to bother, so I didn't. That was many thousand miles ago and I've had no trouble.
So my advice is Protomotive stage 1 w/wo intercooler and later 915 tranny don't cool unless you have one fall into your lap.
If you're going to race, cool the tranny. Call Todd, he can tell you how to do it.
Carl Muckley
Old 03-10-2006, 08:38 AM
Crotchety Old Bastard
RarlyL8's Avatar
My experience with the 915 is similar to rattlsnak. The tranny lived happy for 3 years behind 400HP until I took it to the drag strip. When the trans was tore down we found nothing remarkable that would cause the whinning noise it was making. Further inspection found a warped side plate cover. Wevo parts are on backorder preventing the car from getting back on the road. I chose to add a reinforced side plate cover and dual bearing retainer. It should last for years on the street.
So I guess my answer is don't take it to the drag strip.
Old 03-10-2006, 09:14 AM
WydRyd's Avatar
Drag racing can break anything, but just good, honest power delivery will hold in that box. Just don't kill it when shifting, especially in 2nd gear.
Apparently, EPC or someone like that in Ca. makes pressure plates for the 915 that'll hold 500 lbs/ft of torque or so
"Mike the mechanic" ran a blown 3.2 Carrera using his 915 for years without any issues. He just recently went G50 because he's gone to a TT setup.
Merv
'89 911 Turbo Cab
Old 03-10-2006, 01:42 PM
RETIRED
Joe Bob's Avatar
MY 83 915 lasted 80K, 40 with a stock euro 3.0 (207ish) and 40 with a 3.6 (280ish). The bearing race at the intermediate plate got loose and trashed second gear.
EVERYTHING else was fine......back together with a wevo BEARING RACE retaining piece.
No whines no issues.
2012 ML350 3.0 Turbo Diesel
Old 03-10-2006, 01:45 PM
RarlyL8's Avatar
Where is Mike these days? I never saw his finished TT. The video he made of the blown 3.2 doing a holeshot is one of the most phenominal events I've ever seen a 915 put through and survive.
Old 03-10-2006, 08:00 PM
WydRyd's Avatar
hehe, Mike mostly hangs around at c2turbo.com. He's very busy with work and married life these days
Merv
'89 911 Turbo Cab
Old 03-10-2006, 08:48 PM
Montana 911
k9handler's Avatar
Send a message via Yahoo to k9handler
I am on my second 915 mated to the 3.6...not near 400 hp but they don't hold up as I would like. Then again I have not done all the WEVO and cooler upgrades either.
H.D. Smith
2009 997.2 S 3.8 PDK
2019 Ford Ranger Lariat FX4 Baby Raptor
2019 Can Am Renegade 1000R XC
2020 Yamaha YFZ450R
Old 03-11-2006, 02:26 AM
