bcr4d's Avatar
a/c compressor
I own a 88 cab and am in the process of replacing the a/c compressor clutch. Is there a special tool to use when taking the old clutch off, or is it straight foward. If there is a special tool, where can I purchase it, and what's the cost. thanks in advance.
Billy Crawford
Old 03-15-2006, 03:06 PM
bigchillcar's Avatar
send pelican member jim sims a pm...he should be able to answer this.
ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008
www.friendsofwarren.com
1990 964 C4 Cabriolet (current)
1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold)
Old 03-15-2006, 03:57 PM
Southern Class & Sass
Dixie's Avatar
A strap-wrench is what you need. That and a 10mm socket for the nut.
Dixie
Bradenton, FL
2013 Camaro ZL1
Old 03-15-2006, 04:13 PM
You likely have a Nippondenso 10P15C compressor; check with Autozone. They have a special tool loan/rent program and I believe they have the clutch plate removal tools for this task.
Old 03-15-2006, 04:33 PM
Dixie's Avatar
...and you might want to read thisPelican Tech Article
Dixie
Bradenton, FL
2013 Camaro ZL1
Old 03-16-2006, 04:16 AM
