Me like track days
That little black canister in the center of the picture is the blow off valve.
Relieves pressure from the turbo when lifting off throttle - sends the 'backed-up' and heated air back into the engine. So, if I disconnected the BOV outlet from the throttle body and plugged it - and took care of any issues with debris finding its way back *into* or contaminating the BOV.....anyone with 930s know if there is any harm in futzing with this in this way - for a temporary thing? Kinda ricey, but..... BTDT stories appreciated.
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno |
Me like track days
Crotchety Old Bastard
You want to vent the BOV into the atmosphere?
On a CIS engine the BOV air is recirculated from in front of the turbo to behind it during off-throttle events which equalizes the pressure thus reducing turbo buffetting. This pressure equalization also insures that the air metering plate is not pulled open (shuttered) by the vacuum created during that event. I'd leave it alone.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
Nah, recirc back into the intake for quiet operation.
On my single setup, I vented to atmo and HATED the sound. Now I'm having my two BOV's vent back into the intake for silent operatin.
Merv '89 911 Turbo Cab Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
That is a cheap plastic Bosch dump valve inteneded for recirculation installation.
There is nothing, I repeat nothing, to be won by trying to make it work like a open-ended BOV. Firs of all, it doesn't seal 100% when there is no boost in system so you will end up sucking dirt on low load. Second, it will dump already measured air into atmosphere making engine stumble and go rich when shifting. Connect it back the way it wasm and don't worry about "sending heated air back into the engine". That is not the problem.
Thank you for your time, |
resident samsquamch
Venting to atmosphere with CIS (if that's what you're asking) is a bad thing. It causes the fuel plate to stall which can cause a lean spot.
See PorschePhD's response in this thread: http://forums.rennlist.com/rennforums/showthread.php?t=209805&highlight=Blow
-jeff back in the saddle: '95 993 - just another black C2 *SOLD*: '87 930 GP White - heroin would have been a cheaper addiction... "Ladies and Gentlemen, from Boston Massachusetts, we are Morphine, at your service..." - Mark Sandman (RIP )
Venting the atmosphere is not acceptable in a CIS car. You cannot simply dump it outside for it will cause the plate to fall as stated before.
What you can do it just buy a better valve that will hold up to temperature and open faster. I used to use the Forge bypass valve. Looks exactly the same, but was made of aluminum and used high temp seals. These guys used to sell it. Now they sell similar ones that look a bit more fancy. http://www.stratmosphere.com/index.htm
95' Mercedes E300 Diesel (Azure+Sodalith Blue) 88' Porsche 911 Targa (FOR SALE) (Guards Red) |
![]() I had one of these but black. Here are pics of a broken bosch valve (not good over 15 psi or so) that I took apart. http://www.alvarogil.com/volvo/Photo_Album/CBV/Broken_Bosch/ Here is a great article comparing valves: http://www.s4biturbo.com/art-dvtests.php
Me like track days
Glad I asked. Was thinking of futzing with the BOV for the heck of it.
Most other cars car can take this change with no problems. And I agree with the 'no advantage' - there is none. Cute sound, but it gets wearing. Basically curious if it was something I could play with, aka "dump to atmosphere". Nope. Thanks!
One thing interesting I learnt is that BOV's, like the one pictured above, are not unidirectional. You can actually use either "nipple" as the inlet.
With the side as an inlet, they blow off later and tend to seal better at higher boost levels
