timeless beauty
rcaradimos's Avatar
What's this test port for?
Hey guys I haven't read anything about this item in the pic, is it a test port of some sort?
Bob
Old 03-18-2006, 08:36 PM
Will program for food
ghnat's Avatar
I think that is for the TDC reference sensor.
Greg Hnat
87 Targa Disassembled
90 944 S2 Auto-x, DE and semi-daily driver
98 Jeep Cherokee
Old 03-18-2006, 09:02 PM
Irrationally exuberant
ChrisBennet's Avatar
Like Greg said, it goes to a TDC sensor. That TDC sensor is not connected to anything else and I've never seen a diagnostic that used it. I think it is what racers would call "extra weight".
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 03-19-2006, 05:42 AM
timeless beauty
rcaradimos's Avatar
Thanks Chris and Greg, I think I'll leave the extra weight since I'm not a racer. Would it be used for valve ajustment or timming maybe??
Whatever, just thought maybe I was missing something.
Bob
87 targa
Old 03-19-2006, 09:02 AM
Thrasher's Avatar
Hey guys - I'm having 3.2 starting issues (Stranded! DME Ignition Guru Help needed) and suspect my TDC/Reference sensor - are you saying I can test the sensor using this port? I thought I had to go to the 3-connector harness near the blower motor where it's wired in.
'84 Carrera Coupe - B&B Headers and one-out muffler; K&N Cone intake; Steve Wong Chip; Euro height and corner balanced; 171K Miles (9/12)
Old 04-17-2006, 10:03 AM
Recreational User
porschenut's Avatar
It must have an intended use or Porsche wouldn't have put it there. Is it also on the 3.0 or turbo engines?
Old 04-17-2006, 10:24 AM
Thrasher's Avatar
I was just searching some more in the archives and ChrisBennet commented in other threads that it is actually a third sensor, not to be confused with either of the two pertinent flywheel sensors (reference position and speed) and that it's never used (only for diagnostics).
3.2 ref sensor flywheel sensor questions
Of course it's only $50 as opposed to the $130 for either of the ones you actually need! D'oh!!!
Old 04-17-2006, 10:41 AM
Freybird's Avatar
Good question Bob. I don't mean to hijack, but:
Can contact closure be seen here at TDC whilst manually rotating the motor?
'86 911 Coupe Corner bal track aligned
'09 JCW Mini Cooper '94 Suzuki Carry 4x4
'07 BMW 530xi 6spd '11 Rancilio Silvia w/PID
'79 280zx ported, rally cam(sold) '87 and '95 300Ds, (Sold)
Wisdom begins w/ calling things by their real names; A is A.
Old 04-17-2006, 10:44 AM
Maybe it's intended use ended when it left the factory? I.e. maybe the factory used it for something on the engine test stand?
-Chris
Old 04-17-2006, 11:16 AM
