WydRyd's Avatar
Question Motronic: Surging At Idle & Part Throttle!
I'm having a problem where my engine will surge badly at idle and stall within secods. It also surges violently at cruising/part-throttle, so it's not just limited to an idle condition.
At WOT is *seems* to accelerate fine without surging but I haven't really taken it to redline to ensure it's surge free at the upper end, but it seems fine at WOT.
I can stop the surging at idle by slightly opening the flapper door in the Air Flow Meter with my finger (which makes the mixture richer) so I'm assuming my surging is being caused by a lean condition.
I just had all the inlet manifold gaskets replaced and all vacuum lines seem OK. Also tightened the clamps that joins the two intake plenums.
I have a fuel pressure guage connected to the left fuel rail permanently and it shows the proper fuel pressure at idle (between 36-40psi).
Can the fuel pressure be fine, but the engine still running lean, due to perhaps blocked injectors or something?
If the fuel filter was blocked, the fuel pressure at the rail would be lower, right?
Trying to adjust the brass idle screw at the throttle body makes absolutely NO difference whatsoever.
I've already taken out and cleaned out the ICV/ISV with carb cleaner. Also tested the CHT and it measured up fine (2.8K ohms at room temp).
I'm thinking now maybe my fuel injector(s) are clogged and making the thing run too lean
Any other ideas please???
P.S: Haven't run an O2 sensor for years, so it aint that.
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 03-19-2006, 02:38 AM
bump - id like to hear an answer to this
1986 944 Turbo - Guards Red
Old 04-05-2006, 08:10 PM
WydRyd's Avatar
Sorry, I found the problem to be a dud Air Flow Meter. Replacing it with a known good one fixed the problem
Merv
'89 911 Turbo Cab
Old 04-05-2006, 08:45 PM
jpahemi's Avatar
Merv:
Can you show your presure gauge mounted on the fuel rail?
j.p.
Old 04-05-2006, 09:51 PM
WydRyd's Avatar
JP, it's not actually mounted. I've simply had a stainless steel braided line made up with the appropriate fittings and I have the fuel pressure gauge hanging off the fuel rail test port. It's only there temporarily until I resolve these fuel pressure issues, then I'll remove it.
Merv
'89 911 Turbo Cab
Old 04-05-2006, 09:57 PM
jpahemi's Avatar
Can you tell me where you bought the 12X1.5 fuel rail fitting?
j.p.
Old 04-05-2006, 10:14 PM
i'm looking for that damn 12 x 1.5 fitting also!
i have another question. what does the fuel pressure do when you blip the throttle from idle?
Old 04-05-2006, 10:18 PM
WydRyd's Avatar
JP, I just got the whole line with fittings made by my local Earl's Hoses supplier. I just gave him the specs and he made it up for me.
Dougn1, blipping the throttle only affects the fuel pressure by 1 or 2 psi.
Merv
'89 911 Turbo Cab
Old 04-05-2006, 10:23 PM
What?!?!
DonDavis's Avatar
I'm having a similar issue with my newly installed 3.2. I have to check the fuel pressure but this description sounds exactly like my car. I call it "Go-fastitis". Its only happy when I'm going fast!
I'll check the above items.
running shoes, couple tools, fishing pole
1996 Subaru Legacy Outback AWD, 5speed
2002 Subaru Impreza WRX, 5speed
2014 Tundra SR5, 4x4
1964 Land Rover SII A 109 - sold this albatross
Old 04-06-2006, 09:01 AM
