Alignment question
I am in the process of doing my turbo tie rod conversion. Anyways, i did one side and then went for a spin around the block. Strange thing is it never has driven straight before. It has always veared a bit to the the right, now it drives nice and straight. Does this mean perhaps my alignment was off before. I had it aligned before and it still drove to the right. I took measurement before i did anything and was planning on going back to what it was. It had a toe in of 1/4". Any suggestions?
Thanks, David |
Hey David,
1/4 inch sounds like a lot of toe in. It's possible that the new parts brought the alignment back to "good" settings. Iposted a similar question earlier tonight under the same title.
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
Thanks Wayne,
I will have to check my numbers again. I am really not sure what to make of this. David |
Used Up User
I doubt if you started with 1/4". That would be extreme. 1/8" or 1/16" toe would be more likely. The pull 'right' could have been a slight difference in the right/left tierods lengths - btdt. Was your steering wheel exactly centered?
Oh Haha - I saw your post too. Carefully string setup - Scrugg's method - is the most accurate home measurement imho. Ian
'87 Carrera Cab ----- “Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.” A. Einstein ----- |
Thread Tools | |
Rate This Thread | |
