Guys,
What's the recommended negative camber setting for a daily street car, front and rear? I'm thinking perhaps somewhere between -1.0 to -1.5 degrees all round ![]() Anyone beg to differ?
Merv '89 911 Turbo Cab Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition ![]() Last edited by WydRyd; 03-29-2006 at 08:59 PM.. |
The factory says 0 front and 1 degree neg rear.
Thanks. That's with the factory suspension and FUCH's though, right?
I run KONI adjustables all round as well as 235/40/18 up front and 285/35/18 on the rears ![]()
Merv '89 911 Turbo Cab Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition ![]() |
Right.
Well, I ran -1 front and -1.5 rear and it worked well, nice even wear if you have sticky tires and drive aggressively, but I'm not sure if the big 18's would like a bit less or a bit more or the same. It would probably be a good starting point.
Steve '08 Boxster RS60 Spyder #0099/1960 - never named a car before, but this is Charlotte. '88 targa ![]() |
Somatic Negative Optimist
The more negative camber, the more you run on the inside edge of the tires.
For mildly aggressive street driving with your extra-wide tires, not more than 1 deg front, and 1.5 rear.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ". ![]() |
coolcavaracing.com
Would -0.5 front and -1.0 rear be good on 17"?
Pål (Paul) - The Norwegian lost in Finland... 1978 911SC 3.6 | 2001 Boxster S Racing Car | 1966 912 based 911 RSR replica racing car (for sale!) come and follow the Porsche Sports Cup racing fun and me at www.facebook.com/coolcavaracing ![]() |
I actually got better turn-in with less front camber. If you have a stiff suspension that doesn't roll much at street speeds, too much negative camber will give you a longer contact patch just when you need a wider one.
So with stiff suspension, maybe -.5°. With stock suspension, probably a bit more would work best. |
How would you know if more negative camber would be better if you've never baselined your experience from factory settings?
By trial and error.
0.5 front and 1 for the rear sounds good to me for street driving. I tried a few different settings and this feels good to me. Many threads and posts and opinions on this issue and too many confuse street driving with track driving.
Shouldn't camber be setand fine tuned by recording tire temps after track driving or street driving (then look at tire wear)?
1980 911SC Targa 3.6L |
I'll see what the workshop recommends, but I might suggest -1.0 and -1.5 to them to see what they say.
Thanks.
merv
there's much much more to it than just camber. i find front toe adjustement to have a huge affect on the handling of my RS rep - particularly turn in. find a specialist suspension shop and let them set the whole shooting match - camber/castor/toe/rake/ride heights etc. the setup i use now came from giving the car to a suspension shop with the instructions: "i'm off to targa tas next week, do your thing". also, get them to corner balance the car with a weight equivalent to you in the driver's seat.
Cheers, Ryan 1969 911E (historic racer) 911ST replica (tarmac rally) |
Depends on how aggressively you drive and how long you want your tires to last. I ran with 1.0 front and 1.5 rear and went thru a set of tires in about 8000 miles (Yokohama AVS Intermediates). Went with 0.5 front and 1.0 rear and tires now last about 12000-15000, but still get most wear on the inside shoulders of all 4 tires.
Hi Ryan, yup, it's going to be corner balanced and aligned too, but I just wanted some advice on the camber settings cause my old P-Zero's wore out real fast on the inside. The -ve camber was just way too agressive and they wore like a mofo. For a daily street driven car, I want these new tyres to last as long as possible
On the street, its pretty much entirely a tire wear issue, particularly if you're running stiffer suspension than stock and big tires. Some guys deviate to get fender clearance, but you've got a widebody, right?
On the track, its another issue entirely and it depends on what your tires "like". Toe, on the other hand, is instantly noticeable. In on the street, neutral or out on a track/ax car. With big tires, neutral or out on the street really increases driver workload.
Greg Lepore 85 Targa 05 Ducati 749s (wrecked, stupidly) 2000 K1200rs (gone, due to above) 05 ST3s (unfinished business) |
