Dropping Motor. What else should I do while it's out
Hey guys,
In the next few weeks I plan on dropping my motor for the first time to have the transmission refreshed. Here is what I also plan on doing while it's out. Any other suggestions? 1. Replace engine sound pad 2. Remove and clean fuel injectors 3. Replace vacuum lines 4. Replace rear (and front) shocks 5. Replace motor mounts Thanks.
Mike '84 911 Carrera Coupe (totaled) '83 911 SC Coupe ‘06 Aston Martin Vantage V8 |
Wayne's 101 projects book has a nice list.
Sheena is a punk rocker Suzy Is A Headbanger Heidi Is A Headcase Judy Is A Punk The Ramones' earliest titles included 'I Don't Wanna Walk Around with You,' 'I Don't Wanna Go Down to the Basement,' and 'I Don't Wanna Get Involved with You.' Dee Dee later said, "We didn't write a positive song until 'Now I Wanna Sniff Some Glue'." |
Detail the engine compartment to make it gleam.
Straighten those AC fins. Repaint the engine compartment. Powdercoat the engine tin. Rebuild engine. New paper hoses? Airbox cover has been repainted with epoxy appliance paint and stickers from Porsche since this picture for more gleam! Dirt and dust just tumble off the surfaces.
78SC coupe, Silver Metallic |
Recreational User
Thoroughly clean the engine bay and detail the engine. It's so nice when they're clean and the only time you can really do it is when the engine is out.
Also: 1. Convert to twin plug 2. Upgrade to wacky cams 3. Add ITB's 4. Mahle 3.4 HC P&C's |
Valve adjustment, very easy with the engine out.
Detail engine compartment / motor. Have the tins powder coated. etc, etc, all depends on how much you want to do & how long you plan to have the motor out. Also, make sure you get all the old foam and as much adhesive off before you install the new engine pad.
ßrandon |
Oh yea, polish and clearcoat the fan. Powdercoat the fan housing.
MBruns for President
Take a picture of you inside the engine bay
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Remove and document all plated hardware and have it replated ...CAD or yellow dye chromate.
Warren & Ron, may you rest in Peace. |
Clean the engine bay well -- here's mine
UFLYICU
Replace speed & reference sensors on the flywheel.
_______________________ Racer Rix Spec911 #5 prc-racing.com |
Mike,
If you need any help give a shout. Are you going to Hershey? Dave
Gemini Blue 73.5 911 T Sold 1994 C4 Widebody Sold |
In addition to the 30K service stuff (plugs valve adjustment, etc) be sure to replace and re-torque the intake manifold gaskets (a snap with the engine out...)
1995 993 ('Under my Care') 1989 911 ('Go Pitt') 1996 993 ('Go Navy') 1984 911 ('Go Pelican') |
Replace common oil leak seals.
Doug
Doug 79 SC Targa w/ ITBs, 2004 Cayenne Turbo |
Replace rear shocks.
Bill 997.2 |
Accelerator bushings, shifter bushings, oil sensor, thermostat o-ring, cv-joints
I did the above+ when I dropped my engine to replace with a newer tranny.
1982 Porsche 911SC Coupe - Factory Short Shift |7:31 R&P in AL case | Toyo RA1 Tires | Corbeau TRS seats | M&K 2 in 2 out muffler |
I'm just finishing up the very same project. I spent a ton of time on just cleaning dirt and grime off the engine/trans and bay area. A quick steam cleaning would have been ideal before doing anything else.
Other things I did: clutch, pilot bearing and rear seal, repacked cv's, rear shocks, cam oil lines, chain cover gaskets, op switch, replaced various seals and gaskets, and detailed/painted parts. I decided against expandable oil return tubes because they didn't look adequate enough. They would have been easy to do while the ugly and heavy exhaust is out but... jt -84 targa |
Warren Hall Student
One more vote for replacing oil seals. Particularly for the pressure and temp sensors.
Bobby _____In memoriam_____ Warren Hall 1950 - 2008 _____"Early_S_Man"_____ |
-valve adjustment
- replace hard-to-reach top of engine oil seals ( thermostat, various senders) - maybe even the fuel lines if this is a 3.2...as it seems to be. - Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
oil tank stuff...
& if it's a 72 or earlier, swap the bolts around on the banana arms good time to put in the Al arms if you don't have them - you will actually have room to torque the bolts w/engine out.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
install twin turbo
post pic w/Zappa reference |
