david.avery's Avatar
993 caliper conversion: heat shield questions
Hey all
Starting on my 993 caliper conversion (wilwood front rotors, 930 rear rotors) , and I was wondering... did you guys mod your heat shields or remove them entirely (F+R)
It looks like the rears hit the 930 calipers pretty good, but not sure on the fronts yet. Off to the local auto parts store for some stuff.
Thanks!
David Avery
05 Lotus Elise (sold) | 08 BMW 135i
visit FocusedE, my e-business company | visit Spyderclub
Old 04-01-2006, 11:11 AM
North Coast Cab's Avatar
Remove
1985.5 944 GTS
Old 04-01-2006, 11:31 AM
Remove em all John? Thanks a bunch
David Avery
Old 04-01-2006, 12:00 PM
PorscheGuy79's Avatar
Remove, helps improve air flow around the rotor.
Matthew
“Sometimes the questions are complicated and the answers are simple.”
Old 04-01-2006, 12:02 PM
Bill Verburg's Avatar
You can keep the fronts if you want but the rears need to be removed due to interference.
Bill Verburg
Old 04-01-2006, 02:00 PM
Thanks guys
Install is going quite well. The damn powder coating is flaking in a few spots though. The shop that shipped em back to me did not isolate the calipers well enough inside the box. Looks like a touch up or two is going to be necessary
David Avery
Old 04-01-2006, 07:40 PM
Is there a dirt shield on stock 930 caliper ?
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 04-01-2006, 10:08 PM
Will my ball joints self destruct without them? I just omitted them, and the rotors are on, but if I must I'll pull the rotors trim the shields a bit and pop em back on.
David Avery
Old 04-05-2006, 06:50 PM
yes
Bill Verburg
Old 04-05-2006, 07:07 PM
No, the shields keep water and road debris off the back side of the rotor, is really wet weather it allows a tad quicker response and keeps stones from geting jammed betweem the rotor and caliper. The outer sde is protected by the wheel.
Leaving them off allows somewhat better cooling in dry conditions.
Bill Verburg
Old 04-05-2006, 07:11 PM
Ahh, thanks Bill. Like that first brake application after a puddle where nothing much happens
David Avery
Old 04-05-2006, 07:16 PM
right, I don't drive in rain much or on gravel but as a compromise I left the fronts on and rears off (I had to anyway), cooling on mine is a non issue.
Bill Verburg
Old 04-05-2006, 07:32 PM
