993 caliper conversion: heat shield questions
Hey all
Starting on my 993 caliper conversion (wilwood front rotors, 930 rear rotors) , and I was wondering... did you guys mod your heat shields or remove them entirely (F+R) It looks like the rears hit the 930 calipers pretty good, but not sure on the fronts yet. Off to the local auto parts store for some stuff. Thanks!
David Avery 05 Lotus Elise (sold) | 08 BMW 135i visit FocusedE, my e-business company | visit Spyderclub |
Remove
1985.5 944 GTS |
Remove em all John? Thanks a bunch
Remove, helps improve air flow around the rotor.
Matthew “Sometimes the questions are complicated and the answers are simple.” |
You can keep the fronts if you want but the rears need to be removed due to interference.
Thanks guys
Install is going quite well. The damn powder coating is flaking in a few spots though. The shop that shipped em back to me did not isolate the calipers well enough inside the box. Looks like a touch up or two is going to be necessary
Is there a dirt shield on stock 930 caliper ?
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Will my ball joints self destruct without them? I just omitted them, and the rotors are on, but if I must I'll pull the rotors trim the shields a bit and pop em back on.
Leaving them off allows somewhat better cooling in dry conditions.
Ahh, thanks Bill. Like that first brake application after a puddle where nothing much happens
