echrisconnor's Avatar
Bouncy Tach when hot
New problem. When my car starts to get warm, the tach needle starts bouncing around. Good power, the car runs strong, no stumbling. I haven't checked the ponints gap though.
Any thoughs... CDI, point gap?
'76 911 Carrera 3.0
Old 04-17-2006, 08:58 AM
jdowty3's Avatar
1 vote for a failing voltage regulator. Common symptom.
Jim Dowty
97 911 Coupe (Forest Green metalic, sunroof, leather)
PCA RSR region Insurance chair and Board member
Gruppe B #309
Old 04-17-2006, 09:36 AM
Clean and adjust the points and if it still persists, check the charging system voltage when the tach is acting up.
JR
Old 04-17-2006, 09:47 AM
Fidalgo911S's Avatar
Not wanting to high-jack, but....I get the same problem when the tach gets hot (i.e. direct sunlight on the dash). Also, when I start the car, the red light stays on until I rev to 3000 rpm. Is that an indicator of a voltage regulator failing too?
Nate
Old 04-17-2006, 11:16 AM
Potentially problems in the VR or charging voltage...? Hmm, so just lay a volt meter on the system while driving and see if I'm getting spikes or drops in voltage? What would make the tach bounce? I'm not having any other electrical issues now.
PS. I'll check points gap first, since that was what I was thinking anyway.
'76 911 Carrera 3.0
Old 04-17-2006, 11:23 AM
Autodidactic user
David E. Clark's Avatar
I agree with JR. Set the point gap and check it using a dwell meter. Make sure the points are clean (wipe some paper or an index card between them) and check and clean all electrical connections. Finally, check to make sure the voltage regulator is operating correctly. If this doesn't cure the problem, you may want to consider an optical pickup sold by our host here.
Please help the MFI community keep the Ultimate MFI resources thread and the Mechanical fuel injection resource index up to date. Send me a PM and I'll add your materials and suggestions.
1973 911E Targa (MFI)
Old 04-17-2006, 11:33 AM
Is the VR check just to see if I'm getting over 14 volts?
'76 911 Carrera 3.0
Old 04-17-2006, 02:04 PM
Pretty much. If you can, rig up a voltmeter in the car and check to see if the problem with the tach correlates with any over-voltage episodes, as measured by the voltmeter.
I'd still clean and adjust the points first.
JR
Old 04-17-2006, 04:00 PM
On my 78 SC this problem was followed by a complete failure of the CD unit. I certainly hope it is just a voltage issue and not your CD unit.
Grady aka plain fan
66 912 - enjoying the good life
78 911 SC and 90 C2 turbo look cab - gone but not forgotten
01 996 TT -
09 Audi A4 Avant - daily driver
Old 04-17-2006, 04:06 PM
Pretty common sympton for a faulty voltage regulator, I had the opportunity to experience this first hand last year.
Lincoln Phillip
87 930 Motec EFI M600 G50/50 TurboKrafted Hell Hound.
Jeep, Chrysler, Dodge, Ram, SRT & AEV Dealer pm me for your Mopar needs.
"the 930 is THE CAR that started my PORSCHE love affair..." Magnus Walker
Old 04-17-2006, 04:48 PM
rnln's Avatar
Mine has similar but diff sometimes. When it happen, does the engine run diff or just the tach meter bouncing?
My car has similar problem when getting hot, not all the time, but not only the tach meter is bouncing but the engine rev funny too. It acts as you are steping on the gas pedal and let go and keep continue doing it. Tach meter jump up and down between 800/900 rpm to close to 2k rpm.
Fat butt 911, 1987
Old 04-18-2006, 01:46 AM
The VR is failing and as it gets hotter both from the engine and overcharging it causes the seat belt light to come on and the tach to bounce in most cases.
Lincoln Phillip
Old 04-18-2006, 05:59 AM
bigchillcar's Avatar
points point points. this is always what my tach does when points are either dirty or starting to close..
ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008
www.friendsofwarren.com
1990 964 C4 Cabriolet (current)
1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold)
Old 04-18-2006, 06:21 AM
jdowty3's Avatar
Get a Pertronics Ignitor and eliminate the points variable altogether.
Jim Dowty
Gruppe B #309
Old 04-18-2006, 06:46 AM
