A/C leak, where to have fixed?
I have a small leak in one of my a/c lines, this this something my regular mechanic doesn't work on. My question is, should I have this fixed at a Porsche specialist or would I be okay with a regular shop that works on A/c systems? Bearing in mind I haven't found a shop that works on a/c, but I presume there must be many in this area. Any recommendations?
Many thanks Matt
Matt Kellett 87 Carrera Coupe - Marine Blue 60 MGA - Chariot Red 66 Jaguar MKII - Sherwood Green 09 VW GTI - Candy White |
I have all my a/c issues fixed into a local shop with no problem. Jur need to find an intelligent guy.
1972 911T 1991 Mazda RX-7 Turbo II Are you car loosing power? When was last time you service your fuel injectors? Dirty fuel injectors? Why no try a complete fuel injector cleaning service and return the dignity to you car. Visit www.rennsportfuel.com and we will return your injectors back to life! |
So, the question then should be, does anyone know of a good a/c shop in the bay area?
Matt
The biggest scam in the world is to unscrew the schrader valve
and you have a life time recharge customer. Just buy a valve stem tool and see if you can tighten the core first. Keith Epperly 87 slant nose turbo look carrera cabriolet |
also you can check the fittings if they looks greasy or wet with oil tighten it because they are leaking.
