Rust-O-Leum 7777
Is this ( #7777 , rattle-can) the proper Rust-O-Leum for the semi-gloss black look of a Fuchs center...... Man, it looks awfully close ! .... anyone know for sure ??
- Wil
Old 04-19-2006, 09:36 AM
jackb911's Avatar
Hi, Wil,
Yes, the Rustoleum 7777 Satin Black is perfect for Fuch centers and also works well on refinishing black anodized window trim. It is durable and tough paint, but it takes about 8 hours to dry completely.
Jack
2007 GT3
gone but not forgotten: 1987 Carrera IROC backdate, '89 Carrera M491, '96 993, '93 964 RSA(two), '00 996, '97 Boxster, '79 911SC, '78 928, '76 924, '75 914, '74 911, '74 914, '72 911E, '72 911T/V, '71 911T, '70 911T, '66 912, '65 356C, '61 356B roadster, '60 356B
Old 04-19-2006, 09:45 AM
jackb911's Avatar
Here's a picture of a Fuchs wheel I painted with Rustoleum 7777 about five years previously. It has held up quite well.
I recently sold the car to my brother, and we are going to repaint the centers using Rustoleum Semi-gloss Black this time, as he wants a little glossier than stock finish to compliment the polished rims. But the 7777 Satin Black is identical to the factory "dipped" finish.
Jack
2007 GT3
Old 04-19-2006, 09:51 AM
Thanks !!!.... good info .....
Anyone have pics (and parts #'s) of the glossier black Rustoleum paint on Fuchs?
- Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 04-19-2006, 12:36 PM
msk1986911's Avatar
I used Rustoleum Satin Black as well and am pleased with the results.
Old 04-19-2006, 08:45 PM
Zeke's Avatar
I've used it for years. My old '77 Targa was the first year of the black bar, IIRC, and it needed painting. The satin black was perfect. However, Targa bars have a little texture to them and a spray can is OK. I don't get an Al Reed finish out of a can.
Old 04-19-2006, 10:05 PM
jackb911's Avatar
Wil,
The part # of Rustoleum Semi-Gloss Black is W7798
No pics yet, but wil post soon, as my brother (Stormmaster) just painted the centers on his Fuchs with this.
Jack
2007 GT3
Old 04-20-2006, 05:57 AM
stormmaster's Avatar
Send a message via AIM to stormmaster Send a message via Yahoo to stormmaster
ask and ye shall receive
Hard to get a good quality pic in a semi dark garage....its kinda nasty weather out today....hopefully they will be mounted and polished up by this weekend....these are not fully gloss....just a little glossier over satin...I like the look a lot better...also plan on doing all the trim on the car to match.
Don Booth
87 Carrera Coupe (Current)
70 911 T Coupe
74 914
Old 04-20-2006, 06:22 AM
Once it is sunny out and can get a better photo I will send one with them mounted on the car they look much better than these photos indicate.
Don Booth
70 911 T Coupe
74 914
Old 04-20-2006, 06:26 AM
Good feedback from all.... thanks ....
Wil
Wil Ferch
Old 04-20-2006, 08:55 AM
Here are what the semi-gloss look like....
Don Booth
70 911 T Coupe
74 914
Old 04-21-2006, 05:25 PM
msk1986911's Avatar
What did you use to clean up the unpainted portion of the wheel?
Old 04-21-2006, 06:38 PM
Mothers aluminum polish and elbow grease....took me about 15-20 minutes a wheel....Just did a quickie clean up...nothing elaborate
Don Booth
70 911 T Coupe
74 914
Old 04-21-2006, 06:46 PM
Maybe a stupid question, but does this Rustoleum #7777 match also apply to the Fuchs (albeit excepting the petals) from early Pcars? The original Fuchs from my 73.5 could use some tlc. I assume that this diy fix would not preclude a job by Weidman or Reed in the future. Thanks.
Ass-engine Nazi slot car -- PJ O'Rourke
Old 04-21-2006, 09:33 PM
I think the "Satin" black applies equally well to all eras of the Fuchs wheel where black was used for a portion of the center.
You only need to slightly roughen-up the black..and spray over., Harvey Weidman , Al Reed and I had lengthy discussions on this point..and Harvey even posted on one of the threads....
...for example.."Economy RSR Finish" thread, here---> Economy RSR Fuchs finish ???
- Wil
Wil Ferch
Old 04-22-2006, 08:09 AM
Stormmaster:
Thanks for the pics of the semi-gloss...looks really nice...
I'm torn...maybe like others... in that this isn't the "original" look, but in many ways it looks "cleaner" and the sharp curve of the petals along their length throws off a "white line" shine that looks clean and shows-off the shape and contour of the petals/spokes better.... actually a very nice effect.
My dilemma ( votes on this , maybe?).... applied to an 85 Carrera...obviously a bumper-car:
- satin black?
- semi-gloss black?
- Economy RSR ?
For clarity..car also has "turbo" spats in front of the rear wheel wells..if it matters. Car paint is S7/936 Silver Metallic.
I really like the RSR finish but a part of me says you need really deep/wide Fuchs and a wide body to pull the "look" off on a mid 80's Carrera. That proll'y leaves the two black finishes...??
Thoughts?
- Wil
Wil Ferch
Old 04-22-2006, 08:18 AM
Whenever I get enough money I will change my wheels to RSR finish....until then...they will get a coat of semi-gloss when needed....it takes very little time to mask them off....and scuff and shoot...although I let them dry over night....
Don Booth
70 911 T Coupe
74 914
Old 04-22-2006, 03:11 PM
What did you use to paint the lug nuts? I had my tyres changed and I asked them to remove the lug nuts by hand. Of course they used an air gun and of course because the car was an 88 they said that is was age and my problem. I now want to repaint them
Jack
1988 Carrera (Fuchs wheels)
Old 07-16-2010, 07:36 AM
jackb911's Avatar
Lug nut painting: Soak them in lacquer thinner to get the crud off, blow dry inside and out with compressed air, smooth with 320-400 grit sandpaper and then with a gray Scotchbrite pad, lightly prime with Rustoleum gray automotive primer, and spray two light coats of Rustoleum 7777 Satin Black. Let dry for at least 24 hours. And make sure you use a "soft socket" with a plastic insert to install/remove them.
They will look like new and will hold up very well. Just make sure not to lay the paint on too thick as it will chip off more readily if you do.
Jack
2007 GT3
Old 07-16-2010, 07:46 AM
Make sure that you do NOT paint the mating surfaces of either the lug nut or the seat on the wheel where they meet.
Nut torque is not be reliable if one or both surfaces is painted. They should both be bare metal.
Old 07-16-2010, 08:59 AM
