SC Brake Upgrade ??
I am looking for some brake upgrade combinations for my SC that require minimal machining, on a medium budget. I am running 15" wheels. The obvious is 78-79 turbo brakes with full floating set up, but this is not cost effective at this time. I was wondering if anyone has done early 944 turbo calipers on Carrera rotors up front, is this a bolt up?? Also I have heard of 964 4 piston rears and a Carrera rotor on the front of SC's. Lastly would be the 917 style calipers with later non-floating discs?? Will this work ?? Any advise would be greatly appreciated.
Old 04-20-2006, 09:40 AM
Jim Smolka's Avatar
One of the simplest upgrades is to install Carrera 84-89 calipers and rotors. The calipers bolt up and they are wider as to fit the wider rotors. The rear calipers have bigger pistons, so a Carrera proportioning valve may be a good idea.
'75 914-6 3.2 (Track Car)
'81 SC 3.6 (Beast)
'993 Cab (Almost Done Restoring)
Old 04-20-2006, 10:23 AM
OK, who's got that link. C'mon, you all know the one I'm talking about. Was it Bill V.'s??
xw,
this is what you need to see. It details the options for you in order of cost and effectiveness. Try a search.
Edward
993: retired Trackmeister, now daily driver heaven
911SC: resident Trackmeister-in-progress
Old 04-20-2006, 10:39 AM
Bill Verburg's Avatar
You mean this one?
Bill Verburg
Old 04-20-2006, 10:42 AM
Well I didn't post the question, but thanks, Bill! I can't tell you how often I've seen posts or references to your excellent write up. You are a real asset to the Porsche community.
Edward
Old 04-21-2006, 07:54 AM
randywebb's Avatar
Everyone should send Bill a beer ...
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 04-21-2006, 09:55 AM
PorscheGuy79's Avatar
I just did this myself, no trouble at all.
Size does matter. (my SC to Carrera brake upgrade)
Matthew
“Sometimes the questions are complicated and the answers are simple.”
Old 04-21-2006, 11:02 AM
Formerly bb80sc
Vipergrün's Avatar
Installing Boxster calipers and Carrera rotors front and rear is a nice setup. However, some will argue the value of going with the Boxster over the Carrera calipers. I have the Boxster setup on my SC -> 73RS Replica and it's nice and balanced.
Cheers
-Brad
2015 Cayman GTS
2015 4Runner Limited
Old 04-21-2006, 11:32 AM
There is nothing wrong w/ it, it is an improvement. It's just that you can get the same bang for a lot fewer bucks w/ Carrera front calipers and rotors and leave the rears alone.
I don't know if anyone else has noticed but a lot of the folks here are umm... frugle
Bill Verburg
Old 04-21-2006, 12:38 PM
My dad has the Boxster/Carrera set up and finds it well balanced and loads of breaking power.
Matthew
Old 04-21-2006, 05:49 PM
Less brakes, more gas!
euro911sc's Avatar
Took me a few hours at most and I had Carreras F&R. Works very well and I have no prop valve.
-michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 04-21-2006, 07:45 PM
Formerly bb80sc
Vipergrün's Avatar
I was under the impression that being able to see the "Porsche" script on the calipers would add 10 HP
In all seriousness, I basically stole the front setup, so it did not hit the pocketbook nearly as bad for the rears.
Would you see any benefit adding a proportioning valve with the Boxster setup? I have not had her on the track yet, but she feels balanced on the street. I fear the rears may prematurally lock on the track, though....
Cheers
-Brad
2015 Cayman GTS
Old 04-21-2006, 08:13 PM
Mad scientist
Peter Bull's Avatar
Sorry for barging in like this, but there is one issue that does not seem to be discussed when upgrading brakes. That is brake pad size versus pedal response.
How does this sound? If you add the same amount of force on a big and a small brake pad, the small pad will compress more because the surface pressure (force/pad area) is higher. Since the small pad deforms more than the big pad, the brake pedal will feel more spungy with small pads.
With that in mind e.g. the Boxter caliper upgrade will give a firmer pedal response which gives a better sense of control compared to using a Carrera calipper which has the same brake pads as the SC.
Or am I totally off?
'84 911 Carrera
'91 928 S4
You can't make a racehorse out of a bull, but you can make an awfully fast bull.
Old 04-22-2006, 01:12 AM
Jim Smolka's Avatar
Another factor to consider for track applications is pad cost / life of the pad. Carrera calipers are good, but hard track uses wears out a set of quality pads in a few track days. For this reason on the 3.6 SC, I went with a modified set of 'Outlaw' 4 piston calipers. The plan is to get about 12 to 20 track days on a set of pads.
'81 SC 3.6 (Beast)
Old 04-22-2006, 03:07 AM
No, stock Boxsters front and rear are a tad front biased but nothing extreme, you will just go through front pads a little faster than rears.
Bill Verburg
Old 04-22-2006, 06:03 AM
You are totaly off, while the stiffness of all of the mechanical components can affect brake feel, In 911s it is generally not an issue or at worst a very minor one and pad compression has the least contribution in that regard.
Pedal feel in a Porsche is almost entirely a function of the master to slave ratio.
Bill Verburg
Old 04-22-2006, 06:10 AM
Wangrande's Avatar
Is the 17mm master cylinder of the earlier cars good enough or is a 19mm required? I have done the Carrera front/rear upgrade but have not finished the project yet. Thanks to this post I now know I need the p/v! I am pretty sure my 72 has a 17mm master. I have searched, but found no specifics. Any advice greatly appreciated.
72 T 3.2
Old 04-22-2006, 06:26 AM
Formerly bb80sc
Vipergrün's Avatar
Thanks Bill.....and sorry to the original poster for the hijack, hopefully it was helpful
Cheers
-Brad
2015 Cayman GTS
Old 04-22-2006, 06:27 AM
Your '72 certainly came w/ a 19.05mm m/c.
For Carrera f/r brakes that will work fine, A slightly better m/c would be a 20.5mm m/c 901.355.012.04(ATE# 3.2120-3901.3).
They are not easy to come by
Bill Verburg
Old 04-22-2006, 06:49 AM
Mad scientist
Peter Bull's Avatar
You are totaly off,
Hmm, too bad. After having rebuilt the calipers, changed to steel braided brake hoses and being told by the local Porsche workshop that "oh no, an old master cylinder does not make the brakes feel spongy", I was kind of hoping that was the answer to the spongy pedal in my car.
Any suggestions?
'84 911 Carrera
'91 928 S4
Old 04-22-2006, 07:46 AM
